Nagisa Auto multi camber adapter. Lowers front by 30mm, pushes wheels forward by 10mm (caster), and adds 2-3 degrees of negative camber. These are very easily installed in about 20 minutes or less per side. All hardware necessary is included.
will I have full control of camber adjustment with these?
No, it just adds an additional 2.5 degrees of negative camber on top of whatever you can get from stock adjustment. I was able to get around -4 degrees at my driving height. This also pushes the wheels forward towards the center of the wheel arch 10mm.
