Trunk Will Not Open/Trunk Jammed
Last Sunday I packed the trunk of 2007 LS 460 full. When I closed the trunk a strap from a backpack became jammed into the trunk lock. The trunk would not open with either the key or the internal release. I called Lexus Road side help and they told me to go to a dealer. The dealer was able to open the trunk by disconnecting the battery for 10 seconds. After reconnecting the battery, they releasing the trunk using the internal release while another person pushed down on the lid. This took all of 10 minutes.
None of these instructions are in the TIS database. I hope this saves someone a bad day with no access to the trunk.
1 Post
This happened to me a while ago.
Heres what i did:
Use the manual Key in either the smart key or the remote to open the trunk...
Using ure right hand insert and rotate the key( while keeping it in the open position )
pull the trunk upwards.
I asked a friend to help me with the pulling and it worked.
Another thing:
Your trunk mite be closed from the button inside the glove box.That button wont allow the trunk to open its like securing the trunk when u have some valuable things in there by hitting the button inside the glove box. Try hitting that and check whether the trunk will open.
BEST
Heres what i did:
Another thing:
BEST
well, i am waiting for my wife to arrive with a wrench so i can disconnect the battery. before finding this i destroyed the trunk with a crowbar attempting to pry it. $$$$$$$$$
wish i had set up my computer first and did a search. never knew this forum existed. i hope this works. thanks.
well, disconnecting the battery did reset something as I was able to move the trunk a little bit while somebody help the trunk release button under the steering wheel. However it wouldn't open all the way until I used the manual key in the trunk lid, after doing the battery reset. Shame on lexus for not knowing this when I called them and putting it in the manual. Now my wife wants a new car because the trunks crashed!
Waaaaaaaaaaaaahhhhhhhhhhhhhhhhh
Wow Apolyton, your first post and you used the search function perfectly on your own! Kudos! ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
And, welcome to the Club, don't be a stranger.
WTH!!! My trunk is stuck too. It's a LS600hL so my battery is in the trunk and can't be disconnected with the trunk not opening. I can't reach the trunk from inside the car because its a damn hybrid. Really irritated.
You might get some helpful information here: https://www.clublexus.com/forums/ls4...procedure.html
I tried pushing down on the trunk, unlock with key, and have someone help push it up. Didn't for work me. Went to dealership, got charged $120, and waited 2 hours.
Two questions, how did they fix it, and why didn't your warranty cover it? Even if it wasn't under warranty, you woud think with a $124,000 vehicle they would do it gratis.
Just irritated because I had food in the trunk because we were getting ready for a pre thanksgiving dinner with friends at my house. Had to drive 45 min to the dealer, wait for them to fix it, drive all the way home, and rush to cook the food before people started arriving at my home.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Hi
My trunk was jammed with a coat jammed in the locking mechanism, I tried every way to open the lock ether by the car trunk switch or the mechanical key pushing and pulling twisting and jaring with no luck
I even called out the AA who also had no luck.
The solution that worked was the one posted on the forum which was to disconnect the battery for 10 seconds and then pressing down on the trunk operate the trunk button, and yes success thanks very much for the help and iI hope that this solution will help others
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
