Lowering module finally installed. Pics inside
Just finished installing my lowering module. Instructions say about 2 hours but it took all of 45 minutes. Changed the cabin filter while I was in there too. I took these pics right after but I cant remember which were the ones on 3 and 5, but 5 is the lowest. I'll drive it on 3.
sounds like the air controller i had on my car. got mine from chung@prestigioussociety.com. you have 2010 ls sport, would work great on your car!
Its a datasystem and like Rominl mentioned, it came from PS, but I got it from a board member in the classifieds. It came with color printed instructions that were as detailed as anything else I've ever done. The only thing I didnt understand was how to actually work the system but I figured it out in about 5 minutes. And maybe Rominl can help me out on this, but I cant figure out how to get it into super low mode. Thanks.
playing from my memory a little bit
car shut off. press / hold bottom left button and start the car. wait for beep, use up/down button to toggle between normal (blue) and super low (red) modes. press bottom left button to confirm. you are done![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
let me know if you need more info
After I installed it and started playing with it a bit, I noticed one side on the front was a bit higher than the other, but the datasystem allows you to adjust the height in the front independently. Its a 1 number difference on the settings and the height is even.
and to clarify a bit, the wheel gap from factory is already different left and right, even for cars with air suspension. what happens is when you lower it, the difference become more noticeable that's all.
also, the height is highly dependent on how your car is standing, whether it's inclined one way or another, etc...
but yes, like you said, front left, front right, and rear are all adjustable independently so you can line everything up
Thanks. Im still thinking if I wanted tinted or not. We're coming up on our fall months here so it shouldnt be so hot but I'll decide during that time since everyone seems to drop their tint prices at that time. I guess not everyone want tints in the winter time.
