corner light bulb swap
#181
I'm trying to order a pair from v-leds.com but it's not letting me checkout?!? Also, I'm a noob when it comes to lights, can anyone guide me as to what to get for both dome lights the same color as the regular led map lights?? Please?? Lol
#182
https://www.clublexus.com/forums/is-...de-w-pics.html
#183
I will be replaceing my Nike lights with brighter/cooler LED's ASAP, also a friend of mines turned me onto this very helpful LED thread in the IS forum!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
"2IS 5000K LED Replacement Guide:
Front Dome (3 slots in '06-'09, 2 slots in '10+): V-LEDS HID 5K WHITE 4 M-SMT 2W HIGH POWER BULBS 194 168 158
Rear Dome (2 slots): V-LEDS 5K WHITE 1.5W 3 LED HIGH POWER UNIVERSAL DOME LIGHT BULB 31-36MM ADJUSTABLE
Vanity Mirror (1 slot for each mirror, 2 slots total): V-LEDS HID 5K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Door/Courtesy (1 slot for each door, 2 slots total): V-LEDS HID 5K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Trunk (1 slot): Xenon White Super Bright 12 SMD Forward Aiming LED Panels - Universal Fitting (V-LEDS no longer sells an LED appropriate for the trunk, so I recommend these JLC ones instead. Please note that JLC sells these in pairs so you'll have an extra. For the best pricing, contact CL forum vendor AUTO Design directly.)
Puddle Lights (1 slot for each side view mirror, 2 slots total): V-LEDS HID 5K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Parking Lights (1 slot for each headlight assembly, 2 slots total): 2 V-LEDS 5K WHITE 194 13 LED LIGHT BULBS 158 168 2825 (See this thread for an in-depth discussion on parking lights: https://www.clublexus.com/forums/ls4...ive-guide.html)
Reverse Lights (2 slots): V-LEDS 5K WHITE 19 LED 8W HIGH POWER BULBS 917 918 920 921 922 923 579 "
If so i'm ready to go
RazorBack1 (04-06-18)
#184
My bad I'm running Garax D4S HID bulbs.
![](http://i37.photobucket.com/albums/e91/vtecboost/GaraxD2C.jpg)
![](http://i37.photobucket.com/albums/e91/vtecboost/GaraxBulb2.jpg)
![](http://i37.photobucket.com/albums/e91/vtecboost/GaraxBulb.jpg)
Got them from CL vendor Car Light Trends.
http://www.carlighttrends.com/Garax_D4R_D4S_s/52.htm
This is probably a dumb question but just wanted to make sure what I am reading is correct.
So these bulbs are direct replacement for the fog correct? No ballast required?
Thanks Guys
#188
Try this search string and look through the posts. Click here ->>> https://www.clublexus.com/forums/sea...archid=8442956
#189
I finally got mine in...now I gotta take my artherits medicine. The said part is, that I want more contrast now, but unless I can rent a hobbit, they will stay the 6k. Oh well, on to the next thing.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#190
Thanks. When I was at Auto Zone, I saw the sylvania silverstar 921s also for about $10 a pair.
I was tempted to get them and see how they look since we had the cars torn apart again. Was wondering how they would look if I wanted to have them blend in with my 4100K HID headlights, but imma cheap baassaad
so I didn't get em. But I may try these for the front domes. They should fit, may be close though. The benefit to these is getting back the true light fade out that the LEDs cut short.
![](http://ecx.images-amazon.com/images/I/51IxrQSPaRL._SS500_.jpg)
#191
#193
Based on the report of heat/failures issues with LED bulbs, are these one from DX ok to use?
Like for the front/Nike : This T10 1.9W 6500K 171-Lumen 38-SMD LED Car White Light Bulbs
or
T10 2W 6500K 126-Lumen 9-SMD LED Car White Light Bulbs
and for the back/reverse light 31mm 1.35W 6-SMD LED 84-Lumen 6500K White Dome Light
or
DavidinCT (06-25-17)
#194
or
or
2nd (your reverse light bulb pic) is actually a dome light bulb and wont fit in the reverse housing..
