afs light is blinking after bodywork.. help!!!!
Old 03-01-12, 07:34 PM
LEXUS714
LEXUS714's Avatar
Default afs light is blinking after bodywork.. help!!!!
i just got my car back from the bodyshop and my afs light is blinking.... thinking bout bringing it to dealer but they gonna give me a hard time about the car being modified..... any help would be great thanks
Old 03-01-12, 08:46 PM
bonafyd
bonafyd's Avatar
Try disconnecting the battery for about a minute & see what happens..
Old 03-02-12, 07:51 AM
caha14
caha14's Avatar
Could there be a harness the shop forgot to reconnect when reinstalling the headlight assemblies? One way to find out would be to look at your lights when you first turn them on AND your engine is running and see if either or both go through the startup process. If they are moving like they are supposed to, you won't miss it, as you know.
Old 03-02-12, 02:40 PM
LEXUS714
LEXUS714's Avatar
Everything is connected and I tried to disconnect the battery but didn't do anything
Old 03-02-12, 02:53 PM
caha14
caha14's Avatar
Ok but is the AFS initializing properly as I was saying? Just want to know if the motors are getting power and functioning on startup, even if some other issue kicks in later.
Old 03-02-12, 03:02 PM
anxiouz
anxiouz's Avatar
I'm going to assume the bodywork was front-end? Sounds like the headlight wiring may have been disconnected, damaged, or is just loose.
What was the body work?
Old 03-02-12, 03:23 PM
LEXUS714
LEXUS714's Avatar
I got the a wald kit installed and the whole car painted ...
Old 03-02-12, 04:46 PM
mike690001
mike690001's Avatar
I definitely would check to see if AFS is working first. Park in front of a wall, and start the car to see if they move. Or have a buddy start the car and you check it out for yourself.
Old 03-02-12, 04:47 PM
LEXUS714
LEXUS714's Avatar
just checked it and no movement at all ....
Old 04-08-12, 03:46 PM
RaXxaa
RaXxaa's Avatar
I know this reply is late but i have seen some other posts where the AFS lights blink because of the afs sensor is not reset after major changes in the supension or ride hight...
The afs light donot move when the car is still, it move after the car is at atleast 5 mph or so.
There are sensors in the rear axles which can be adjusted. when chaning them you might see a change in headlight aim.
hope this helps.
Also you can bent down and see the sensor bolt thrugh the rims. Its rear to the wheel bolts
Old 04-08-12, 09:50 PM
LEXUS714
LEXUS714's Avatar
I gotten it fix .. Plug was loose behind the headlights but thanks
andy350
07-03-21 06:30 PM
showgun82
SC- 1st Gen (1992-2000)
10-19-13 04:07 PM
smokincigs
08-29-12 05:27 PM
313vip
09-19-07 09:00 PM
varcity64
10-11-06 01:57 PM
Quick Reply: afs light is blinking after bodywork.. help!!!!
