2011 LX LED Turn Signal Conversion
I have converted all my exterior bulbs to LED. I have not been able to get the turn signals to slow flash, even with resistors. Do I need an LED flasher relay? What am I doing wrong? Thanks.
Did you wire in the resistors to the back bulbs? Which load resistors are you using? I believe 2011 was the last year the LX used a conventional flasher can go LED flasher if you like. But I hate these units they have a delay between activating and the first flash
https://www.diodedynamics.com/led-fl...xus-lx570.html
If you're good with a soldering iron you can mod the factory unit
https://www.clublexus.com/forums/per...l#post10935174
