Quick Tuneup Question...
Hey guys i'm new here..just wondering if you guys can give me some pointers n tips ...
Just got my 00' Lx470, and jsut want to do a tuneup before I go on a long trip. I just wanted to know exactly where the oil filter and oil drain bolt is, how to reach the spark plugs and what oil do you guys recommend for this 2000 lx470. I took a quick glance at the engine and it seems hard to reach and couldn't find the oil filter..so tomrorw when i start on it i can get it done right away.
thanks,
John
thanks,
John
I can't answer all of your questions but here's the answer to a couple:
To get to the oil filter you have to go through the skid plate on the front end. You'll see a small plate held on by two bolts (14mm maybe?) undo those 2 bolts and off comes the oil filter door. That's your access for the filter.
As far as oil goes I use Mobil1 5w-30 (blue cap on it) and a Mobil1 filter but the filter from Toyota is just as good in some comparison tests I've seen.
Your sparkplugs more than likely are fine as they are not changed for very long intervals by design. Also, the manual gives specifics as to exactly what plugs you need for the engine if you do change them. I've not done this on my vehicle but remember the manual being very adamant about using certain pregapped iridium tipped plugs from NGK.
If I have time I can take some pics tonight for the filter door and drain plug.
Tad
Tad
thanks tad..the car has about 12k miles and hasn't had a tuneup yet..you think the sparkplug needs a change yet? since u were talkin about the design.
actually i was looking in the service manual..and it look like 60k the spark plugs should be changed. wow..that is amazing. tomorrow gotta change the oil. hopefully i can find teh drain bolt easily
NikonGuy
12-20-14 03:15 PM
