spark plug DIY procedure?
is there one available for the 470? I visited my mom over the weekend and drove her 2003 470 (25K miles), and it has much more torque and power than my 98 470 (190K miles). I was wondering if the spark plugs were causing such a huge difference in performance, or is it because I have so many miles.
I tried searching for a write up on the spark plug change, but havent found anything
I don't have the procedure for removing the plugs, but I do have the procedures for removing the coil overs. PM or email me so I can send the instructions to you. Once the coils are removed, just unscrew the plugs out.
-Robert
-Robert
You will have to remove the air intake box, as it goes over the plugs. It's a fairly easy job, that should take you 2 hours or less. I used platinum plugs instead of iridium, and the car runs perfectly.
