LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Brakes bled now HELP
Old 10-21-04, 04:01 AM
ozlx470
ozlx470's Avatar
Default Brakes bled now HELP
Put new Pads, Front and Rear, into the 2003MY Lx470 Today.
Bled the system, making sure Brake Fluid never got under the Min level. Bled with the Engine running. Finished all 4 wheels Far back, near back, far front, near front. No leaks.
Brake warning light now on continously, Pedal is spongy then gets firm then all of a sudden goes soft, the ABS warning light comes on, the VSC TRC and the VSC OFF warning lights come on and the audible warning starts.
Any ideas?
Old 10-21-04, 04:18 PM
LexFather
Guest
Posts: n/a
There is some air in the brake lines. You will have to re-bleed.
Old 10-21-04, 08:00 PM
ozlx470
ozlx470's Avatar
As I thought you were right
Turns out that at the end of a long afternoon of jacking the vehicle, taking the wheels of and replacing the pad I neglected to notice that the Front Bleed points are very coarse compared to the rear ones.
This make it very easy, when using a One Man Bleeder Kit, to miss that air can reenter via the screw thread of the Bleed point thus bypassing the one way valve. Just a tad of too much looseness is all it takes
So, after rebleeding from the Far right I finally got all the air out of just the front ones. Anyone want a few gallons of slightly used Brake Fluid
BTW it is important to have the ignition turned on to keep the Brake Assist resvoir full. The Engine does not need to be running.
Old 10-22-04, 01:07 PM
LexFather
Guest
Posts: n/a
Glad you got it where you want it to be. Would u be interested in writing a LX 470 brake write-up so other members could use as a blueprint?
Old 10-22-04, 04:39 PM
ozlx470
ozlx470's Avatar
I actually used this thread https://www.clublexus.com/forums/pri...hreadid=117244 as the basis and have already linked my (this) post at the end as an FYI.
As I did not take pictures, maybe the original author of the Thread I used would be a better one to ask to update their thread for use as you suggested. Let me know.
Old 10-23-04, 07:43 AM
LexFather
Guest
Posts: n/a
Wow , I messed up, lol
gs450lexus
08-18-18 11:20 AM
Chiguylay
08-30-16 01:55 PM
Pants808
10-08-12 04:47 PM
SynicalVip
09-06-12 11:10 PM
kasper634
GS - 1st Gen (1993-1997)
02-11-06 09:30 PM
Quick Reply: Brakes bled now HELP
