LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
differential oil chnage
Old 12-13-04, 07:23 AM
PitBull
PitBull's Avatar
Originally posted by lx470man
i looked for the drain and fill plugs on all 3 diff's. But could lonly locate the rear diff 's drain plug.
does anyone have a pic of the rest?
If you are having a problem finding these drain/fill plugs, I would suggest you take your LX to a local mechanic that will let you stand and watch them change your fluid. This way you can buy/supply the fluid you want used and you can watch them do the drain and fill for a small charge. Then next time you will be up to speed on how to do the change. Plus this drain and fill is a lot easier on a lift then crawling around on the garage floor. Good luck
GSLexTexas
01-17-17 09:20 PM
propcop
08-05-15 03:00 AM
lbintab
04-20-14 12:38 PM
somnoboy
04-18-11 01:52 PM
BananaGS
Maintenance
01-27-02 11:18 AM
Quick Reply: differential oil chnage
