Bigger Size Tires, Anyone!!
Hi All,
Let me introduce my self!
I use to be an active member on IS300.NET (nick name B2001AS). I sold my IS and now having an '03 LX470 PEARL WHITE. I love it so much.
I want to change my stock tires to a bigger size of tires, so that it will look better/ stronger. (Not too big). If anyone of you has some pictures, please kindly share with us!
Thank you!
SETO
Thank you!
SETO
I suggest you try http://forum.ih8mud.com/ There are lots of Land Cruiser owners that have increased the size of their tires. You can fit a 285/65/18 tire on the stock suspension. That is about ~32.5" in diameter, vs the stock at ~31" in diameter. It is also slightly wider than stock too. That tire size is bassically one step wider and one step taller than stock.
The BF Goodrich All-Terrain KO has a tire in that size. It has a more agressive tread pattern than the stock street tires and would probably give you the look you are going for.
Thank's! I will check it out!!
