dvd bypass questions
hello i know several have done the dvd bypass to let it run while in motion; had some questions has anyone had any trouble with the nav after it was done??? my friend says that the 05 and 06 units with the new sat tuners and stuff have a motion sensor aswell so it would affect the whole unit! Now im sacred to go thru with the whole thing any help???? mine is an 06 model
DVD override
I have an 06 LX and have overridden the Nav so i could use it to find addresses while driving and have not noted any problems. But do you know how to override the DVD so it can be played while the car is in motion? The nav override does not override the DVD--and to play the DVD you are required to have the emergency brake on.
No, I did not buy any kit. There is an override for the Nav (which allows you to enter destinations etc while driving) -- that is a matter of some strokes to the screen. But is there a similar override to the DVD functions?
i second that question i would love to be able to switch dest? also i may be stupid on this one but i have trouble getting the nav to use the route i want. hey by the way has any one seen the blue tooth thing for ipods yet i seen it in a mag at borders but forgot the name of the company that sells it. thanks
NAV Override
A set of button pushes can override the lockout on most 04,05,06 Lexus NAVs until the next time the vehicle is restarted by pushing the buttons in the following order: menu > volume > top left of screen, bottom left, top left, bottom left > override ((hold for several seconds until override is highlighted and beep occurs) > back. Destinations can then be entered while moving
http://www.lextasy.com/nav_converter_1160_prd1.htm
Try to see if this is what you are looking for. Not sure if it will help, just rememberd seeing this somewhere.
Hello!
All years Lexus LX470 and Toyota Land Cruiser DVD override solution you may be found on ebay. http://search.ebay.com/_W0QQfgtpZ1QQ...assZpowerQ2eua
You can change destination for your navigation and look DVD movie in motion on front or rear additional monitor.
This low cost, simple, disasembly not requiring method.(only for watch DVD)
You can try it
You can try it
If all correctly to make that of any problems will not be. I working in Toyota car-service and I have make that on more than 20 models 2006-LX470. Therefore I know.
Brake light??? Why?
Brake light will on when parking brake will be activated.
