Brush Guard LX470
Rather than a brush guard, why not get a real, solid aftermarket front bumper. It'll protect the vehicle, plus give you the look you're most likely after.
There are many vendors who sell front bumpers for the LX 470 -- but one that comes to mind is www.sleeoffroad.com -- look at their selection of front bumpers for the LX 70 (aka 100 series Land Cruiser).
I have installed the 'WAG' brush guard, tail-light guard,and rear bumper guard. It does not affect the lights, it is easy to install through existing bolt holes, and makes the truck look very aggressive. With reguards to prtection, it is questionable if the guard protects or causes more damage. If hit directly from the from, it will proect, but if hit on the side of the front (where the lights are), it is likely going to cause more damage, as the guard will compress and then dent the fender.
damage mutlipliers..
Thats true, I had one on my 1998 LC 5 years ago. Some truck backed into me and bent the guard into my radiator, grill and lights, Caused way more damage than I expected. The bodyshop referred to the brush guard as a Damage Multiplier. I dont think I would get one again. I like the look but its not worth it as they are not that strong and it doesnt take much to have it pushed into your grill, lights and bodywork.
There are many vendors who sell front bumpers for the LX 470 -- but one that comes to mind is www.sleeoffroad.com -- look at their selection of front bumpers for the LX 470 (aka 100 series Land Cruiser).
If Slee notes the bumper is for a Land Cruiser, you'll need to either remove the auxiliary light mounting tabs and have them turned around, or see if you can get one modified for the LX with the mounting tabs facing front...facing rear won't clear the hood as the LX hood lifts with the grill, the Cruiser lifts only the hood.
I wonder of OP's selection has been tested and rated compatible with factory airbags?? If not, safety is definitely compromised from oem, and oem construction is almost bullet proof in a collision.
Do you think the guard will "protect or cause more damage" to the occupants?
danmm7
GX - 1st Gen (2003-2009)
21
01-08-20 11:22 AM
