Air Suspension Mod
Anyone install this or hear of it.
Data system Air Ride Controller
http://www.l-tunedparts.com/product/?id=1633
I've seen similar JDM AHC units that allow one to adjust the front/rear height in 10mm increments while stopped or moving (about $450). I haven't seen the exact one in your link, though. I kind of like the Bernie Blanks one since it looks like it doesn't require a separate box/control. It looks like you just plug in an adapter from the signal entering/exiting the AHC ECU and it overrides the speed limitations imposed by the AHC ECU. I did run into a situation where it would have been great...descending a windy, mountain road (damping set to sport). If one could drop the height 2", it would probably make a noticeable difference in the cornering although you'd lose suspension uptravel (highway was smooth, anyways). OTOH, I can see why Toyota disabled it...probably didn't want someone to ask, "what does this do?" and put it into high just as your cornering fast.
Thanks
Originally Posted by 03LX470
How much is the Bernie Blanks one & does anyone have a URL to it?
Thanks
Thanks
Here are the other ones I've scanned out of the JDM LC book/mag (Hyper-Rev vol 78, LC):
http://us.lexusownersclub.com/forums...e=post&id=4749
mocon1422
12-04-10 06:08 AM
ToyLexmods
13
03-22-03 07:19 PM
