Common Problems in LX 470: Looking to buy 1
I'm looking for a 1998-2003 LX 470. I've searched but I've found no info. about what the commons problems on this car are. For myself, I only found the inner CV boot on the passenger tends to leak after 80,000 miles. Could anyone give me a link or any replies to this precious info?
All replies are greatly appreciated.
Off the top of my head:
'98-99: throttle position sensor (recall), 2 pinion front diff (weak, can blow if backing up uphill or winching someone from the front), rattling cat converter shield
'00: some transmission failures
'04: nav unit
all years:
- exhaust manifolds can crack at 80-100K mi
- starter contacts need replacing at ~100K mi
- AHC accumulators (globes) can fail if prev. owner used the wrong fluid (dissolves the membrane in the globe that separates the nitrogen and AHC fluid)
- AHC wheel height sensors can rust & fail (if you live in a wet/salty area).
I've only heard of the leaky CV boots on people who crank their t-bars when adding a lift, thus changing the angles.
'04: nav unit
all years:
Interesting - do you have any more information on this?
I had the same thing fail on my 2000 LX470 - driving along one day, and all of a sudden, the accelerator pedal just didn't work - press to the floor with no response. I shut down, cranked up again, and it worked, but now intermittently.
So I went straight to the dealer where they kept it for 4days(gave me a loaner) and charged me close to $600.
If this was a known recall issue (even for the previous year), should I have paid anything at all?
From the sleeoffroad's 100 series buyer's guide:
KNOW ISSUES
1998/1999 Accelerator position and throttle position sensors can cause malfunction and cause a situation where the truck does not respond to throttle input.
Starter contact can wear out. The starter is located under the intake manifold.
Thanx Jim,
I just found slee site last night, and edmunds this morning.
Interesting thing though, the edmunds.com site didn't have the accelerator issue listed as a TSB either.
Oh well, guess I don't get to go harp at the dealer for $600 credit.
According to Slee's response here
http://forum.ih8mud.com/showthread.p...ion+sensor+tsb
there was no recall, but maybe a TSB (helps mechanics diagnose the problem in the future).
I have a 99 and have only had a torn inner CV boot, cracked exhaust manifold, and of course the obligatory Nakamichi stereo headunit. That stereo absolutely blows but the car has been rock solid reliable for the last 4 years with +50000 miles.
I keep hearing about the nakamichi headunit going out. I haven't had any problems so far, but I'm starting to get worried, as if the time is drawing ever closer for the thing to fail.
What symptoms will it present before finally kicking the proverbial bucket?
All,
Does the LX always lower itself a couple of inches when you shut it off? My wife says it does and did so over the weekend when we were visiting my parent's place because my dad made a comment about it. I told her that I did not think it went up and down everytime the vehicle went on and off.
Also, is it normal to "hear" the AHC system taking the veihcle up and down? Ours tends to make a little gurgling noise when making it's movements.
Thanks for the input!
Hi, Just got my LX470
But while trying AHC i did not see/feel any movement? Am I doing anything wrong? When do i have to do that? How to do that?
Also the rear DVD playing is playing but cannot hear with the wireless headphone. What could go wrong? headphone lights are on. Do I have to connect something or setup something?
Man doing lot of reading [Manual] but not everything is explained in details. So i will be asking questions to you guys time to time.
Thanks,
Raid
Thanks,
Raid
Ok. Now I can use AHC.
The condition was to close all the doors and then make it high or low.
But as some of you are telling that when you shut the engine it lowers by itself. How can that happen? Like to know if that is automatic.
Also I found one of the DVD's tranmitter is not working? What is the easy fix? How much that could cost? Is it DIY type issue?
Thanks,
Riad
Thanks,
Riad
I may be wrong, but I don't think it's supposed to lower itself when you shut it off. If I stop raised, it stays raised. I actually just it yesterday to jack w/ my buddy who was driving his LC. I parked mine next to his raised and when we got out, I said, "Awwww, wook at da widdle wand cwuiser..." ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Seriously, though, I don't think it's supposed to do that. Unless it's an 03+ "feature".
LX470Pilot, the main Nak problem is the CD gets stuck or stops reading discs. I'd listen for abnormal cd mounting noises or problems playing discs as warning signs.
