LX 470 Suspension System Concerns
Rather than saying I have a problem, I really have a concern. Occasionally, I have had some bounciness as I drive.
Then other times, things seem to be fine.
Currently, when I stop, the car will seem to sway for 2-3 seconds. What does this mean?
I also noticed a clicking sound as I turned and took it to the Lexus dealer. He fixed the tie rod and that part is fine. He said if I have contaminated the suspension system then it is an extremely expensive repair.
Thanks.
Bounciness signals that the accumulator globes are going bad. There's a membrane inside the globe that separates nitrogen from AHC fluid. If someone adds the wrong fluid into the AHC resevoir (I've heard of brake fluid being added by Toyota techs not familiar w/ AHC, wiper fluid added by Jiffy lube), it will degrade the membrane and the nitrogen leaks out. Put your AHC in low and record the level in the resevoir. Then put it in high and do the same. You should have at least 7 gradations difference between the two settings. If not, the globes are shot. Like any part, they will eventually degrade even if you use the proper fluid, as nothing lasts forever, but there are plenty of guys w/ '98's with well over 120K mi and their AHC globes are fine. Although the owner's manual says to change the AHC fluid every 60K mi (5 yrs driving), I think the fluid absorbs water like brake fluid. If that's the case, and you live in a humid environment, it might be a good idea to change it sooner. I plan change mine every other year, have the dealer do it so I don't any crap about it not being properly serviced if the globes do go south in the future.
Jim, Thanks for the reply. Are the globes going being shot and the membranes within them leaking nitrogen the same thing. Sorry about such an ignorant question.
If I have to change the globes, is that very involved? 1k or 3k?
Will changing the fluid help the bounciness or after the bounciness starts is it too late?
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
same problem here, so if we go to the dealership< we should expect to pay 2 k correct/ and if we continue to drive with the issue< will it get any worse, because it only occurs every once in a while and for us, now is not the greatest time to spend 2 k on a problem that doesnt occur all the time
Please go to 'activesuspensionsystems.com' and read all about the AHC system. Dealer price to replace front 2 accumulators is +/-$2000. All 4 is twice that or more. An easy DIY job using aftermarket parts from above site
gunluvS14
02-18-05 03:09 PM
aftermarket, ahc, arbkaymar, brake, concern, fluid, leaking, lexus, low, lx470, ome, remove, repair, suspection, suspension
