HELP ME I M HAVING PROBLEMS WITH the LX
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
1) half the truck is high, half low: AHC sensors are corroded. A common problem in areas where roads are salted. Get new sensors and seal them w/ silicone caulk.
2) bumpy ride (like no shocks?): usually signifies the damper globes are shot, often from someone putting the wrong fluid in the AHC resevoir.
I'd fix problem (1) first and flush the system w/ new AHC fluid (Toyota brand AHC, not hydraulic fluid, brake fluid, or anything else). Then put the AHC in low, check level on resevoir. Put AHC in high, recheck level. The levels should differ by at least 7 gradations. If < 7, replace all 4 globes (at least $2K) and next time, don't let anyone "check the fluids."
turns out this suspension is a big problem. we have a friend with an 06 ewhoes had it occur to her on 3 different ocasions, but anyways, is there any where to get this problem fixed other then the dealership, can a place ;like midas or something along the lines of that be able to fix the problem?and if not were is a cheaper place to go
FYI, some of the '05's and everything from '06 on is made by Toyota, not Araco. Araco, a builder of custom high-end coaches in Japan, had built the landcruiser for about 50 yrs plus all the LX's up to about '04-05. Rumor is, quality has dropped from the buy-out by Toyota, 30 yr Araco assembly line veterans retiring, etc. If it's made by Araco, there will be a sticker either under the hood on the right far corner or in the passenger's side door jam.
Hmmm, with my brother '01 LX having exhaust manifold issue, possibly the beginning of starter issue, and AHC suspension issue all at 60K miles, i am starting to wonder about the great Lexus reputation.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
The suspension is Lexus design and materials. I would NOT trust anyone else working on it unless they are certified by Lexus or used to be a Lexus mechanic.
Hmmm, with my brother '01 LX having exhaust manifold issue, possibly the beginning of starter issue, and AHC suspension issue all at 60K miles, i am starting to wonder about the great Lexus reputation.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Your best bet is the lexus dealer. I wouldn't even trust a toyota dealer w/ AHC since the landcruiser didn't come w/ AHC in the US until '06, plus landcruisers are so few and far between, toyota techs seldom get to work on them.
The only problems I've heard of happening on all landcruisers 100's/LX470's is the exhaust manifolds tend to crack (not sure if this has to do w/ lots of short trips or anything; we won't know if it occurs on the 4runner V8 or GX until years later since they're so new). The symptom is a "ticking" sound upon startup (engine cold) that eventually disappears as the engine warms up. The second common issue is the starter contacts will need replacing (a wear item). The problem is the start is located under the intake manifold, so hard to access. When your contacts are about to go, you'll get the symptom of the engine not starting some of the time (it's a graceful degradation).
As far as AHC issues, the there are none that are design related. I've only heard of corroding sensors in vehicles driven on salted roads and the membranes in the damper globes failing from bad fluid (usually someone has added the wrong fluid [like brake/hydraulic fluid], or excess water in the fluid from lack of changing, etc.). The wrong fluid takes time to damage the membranes, like a couple of months, so by the time the symptoms appear, you're not sure what caused it. As far as salted roads, you can always live somewhere where they don't salt the roads.
hmm now wat is the probelm is around for like 2 days, then goes away for a week, then comes bac, but not constantly, in other words, it doesnt occur all the time, sometimes the supsension just goes back to normal, will a simple change of the fluids, and checking the sensors fix the problem if the problem is not constant ?
Please go to the following web site and read a lot more about the AHC suspension system
"activesuspensionsystems.com"
Corroded height sensors are not a common problem in the past, maybe now though they are developing. MUCH lower cost (and a real simple DIY job)to replace the OEM accumulators with the one offered on the above website.
AVnGX
GX - 1st Gen (2003-2009)
24
12-25-13 12:30 PM
Scarletthi
04-18-11 11:32 AM
