2000 LX470 rear A/C blows HOT
Anyone have a similar issue - our rear A/C blows hot air (like my mother-in-law) all of the time now...does anyone have the same problem? What do you do to fix?
Thanks.
Thanks.
Bad luck, AC tubbing is attached to the frame and not accessible unless you were to lift the upper body off the frame, thank God your front AC is still operating. Simply do not use rear AC. Sometimes leak in the rear system causes freon to escape and you will loose front AC. Unsupported fix is to cut and cap the tubes going to the rear and disable rear AC alltogether. Bad luck as I said above, must have rear AC? consider upgrade to newer model 2006 up. Repair will cost big $$$$$.
Nauticalx
08-21-09 12:43 AM
