Please help! 02 LX470 navigation/radio/ac stopped working (lost power)?
I started my LX470 earlier, then about a minute later plugged my cellphone charger into the cigarette lighter outlet.. It made the nav screen flash, and then went completely blank along with the clock. None of the buttons from the bottom to the top work. Checked the small fuses under the hood everything seems ok... has this happened to anyone else? Is there another fuse panel with other fuses? Any input would be greatly appreciated. Thank you!
There is an index at the end of Lexus Owner's Manual.
Fuse types, Fuse box and Fuse locations are listed there.
If you need an owner's manual, it can be downloaded from the lexus owner's link on the lexus.com website.
It will be better to proceed checking the fuses, with the help of the owner's manual.
Thanks for the reply, was hoping for something a little more direct and detailed.. I unfortunately do not have the owner's manual, and can't find it on lexus.com .. I must be overlooking something. Thanks
Fuse Box Locations:
Engine Compartment
Driver's side kick panel
Passenger's side kick panel
Fuse numbers, ampere ratings and diagrams are somewhat too detailed to list here.
My model year of LX470 is different from yours and, the layout and specifications of fuses may not be the same.
Suggest going to the following link in lexus.com and register to download the Owners Manual for your model year:
https://secure.drivers.lexus.com/lexusdrivers/home
That will be the first step.
Other members may chime in.
Engine Compartment
https://secure.drivers.lexus.com/lex...html&locale=en
it's unavailable online right now. I didn't look around passenger side kickpanel for any fuse panels. I read somewhere that someone had the problem and it was the CIG fuse, a 15amp, I'm just not sure exactly where it's located.
Nav screen and ac controls are not tied into cig outlet fuse, you are looking for something "bigger" than a fuse, or multiple fuses. What did you plug into the outlet?
edit, NM, I see you said cell phone charger.
HAve you had anything done to the vehicle recently?
