2005 Lexus LX470 ODB Codes
The ABS, VSC & Traction Control lights just turned on in my 2005 Lexus LX470 after is sat for about two months. A friend with a scan tool checked the codes and this is the result:
C0205 Front Speed Sensor - Left Front
C0210 Rear Speed Sensor - Right Rear
C0215 Rear Speed Sensor - Left Rear
C1223 ABS Control Malfunction
C1340 Open Circuit in Differential Lock Signal
I can't believe that all these items need to be replaced. Any suggestions on where to start?
Any help would be greatly appreciated. Thank you in advance!
I have a 2002 LX470 with a similar problem. I have ABS, VSC TRAC and VSC OFF lights all of the sudden. The car was handling just fine so I thought I could drive it until I figured out what was going on. Not recommended. I made a sharp right hand turn at a stop sing to get onto a street and the ABS started modulating, just about took the wheel out of my hand. It sits in the garage until I figure this out.
On many cars there is usually a way to dump the codes. I know how to get the AC to dump the codes to the GPS Display. I suspect there is a way to get the ABS or VCS lights to flash out some kind of code that you could then reference a look up table to see what is going on. Does anybody know how to do this? If so, can you also provide the look up table?
Thanks in advance.
Thanks in advance.
When I got the dash lights it was because I had filled up at the gas station and forgot to tighten the gas cap sufficiently. Lights went out after a few running cycles. No problem.
jrmyrnsm
GX - 1st Gen (2003-2009)
06-29-19 05:03 PM
Globalinx
03-04-14 01:17 PM
