Rear wiper motor
I can hear and feel the rear wiper motor moving around like it is loose, inside the the rear door cavity when on. How do I access this motor to see if I can tighten it up? I am afraid to pull panels off rear upper door, as I dont want to break something.
Lx470, year 2000
Lx470, year 2000
To access the motor open the rear hatch and start with the door handle, theres a screw somewhere there then once that is removed you can just carefully pull on the platic pieces and they should pop out. I have had to grease the joints to the rear wiper numerous times, its not that bad
