Originally posted by Lancezl1 Does anyone know if a 98-00 LS400 steering wheel will fit a 98 LLX470?
You would need to make sure the hub's of the wheel base are the same. As far as the wheel it should not be a problem with fittment. You should worry about the air bag as well. This may not be some thing that crosses over.
LS wheel will not fit LX - airbag connector is different. If you are looking for the wood wheel for your LX any 00, 01 or 02 will fit w/o modification.
