AHA suspension, concerns
Hello everyone, I'm getting ready to pull the trigger on a 99 lx470 with about 100k miles, im new and have questions as to why this AHA suspension on the LX470 is problem down the roads, was it a bad engineering parts or abuse from owners that it eventually breaks down? Why is it so unreliable?? Was reading they eventually breaks down and it's expensive to replace, can someone explain to me what really is the issues with these AHA suspension?
You read it on the internet, and therefore it must be true...
It does not necessarily "break down".
It is not "unreliable".
It is not expensive to replace...if you think $2K to switch from AHC to non-AHC is beyond your ability, I'd suggest considering a Land Cruiser around the same year.
I'm not aware of "issues" with AHC...other than owners who can't understand the maintenance schedule in the owner's manual
How long has it been since the fluid has been changed in the truck you're considering. What do Lexus' records tell you?
Steve
So...
You read it on the internet, and therefore it must be true...![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Steve
Steve
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Steve thank for your insight, like I said I'm new to the forum and just learning more on these lx470, I did a lot of searching and reading on the suspension and from what I gather, people switch out to regular suspension, thanks again for clearing this up regarding the AHA suspension on the lx470
Take a look at the 100 series newbie guide on sleeoffroad.com...it will tell you what to look for on a used Cruiser or LX.
I'd also check out AHC threads in the 100 series forum on ih8mud.com. I'd also recommend going to the owners' section on Lexus.com. You can plug in the VIN and get a complete history of work done on the truck by Lexus dealers from initial delivery forward. Service records there will also tell you what recommended service tasks were declined by the owner. If you're in a state where roads are salted in the winter (not sure if your location is in Canada or California), it's imperative you take a look at the LX on a lift with both under-body shields are removed.
The field test for AHC is to simply drop the truck to the low position and note the fluid level (masking tape on side of tank + sharpie), then raise the height up to the high setting. You should see the fluid level drop by at least 8 graduations on the side of the AHC reservoir. While driving over a slightly bumpy road, you should feel definite differences between the damping control set on "comfort" or "sport". The comfort settings will give you a very smooth freeway ride, the sport settings a slightly bumpier ride but less body lean on curves.
hth
Steve
You're welcome
hth
Steve
hth
Steve
Vince
Steve
That would depend on which non-AHC torsion bars and springs you use...obviously, using Land Cruiser parts will result in a ride about halfway between comfort and sport. Using non-toyota parts, e.g. OME, you've got various rides to chose from. I'd check sleeoffroad.com.
Steve
Steve
