Led or HID for LX470
Hello friends I'm a new owner of the 2006 LX470 , wanted to ask if anybody put Led bulbs for the headlight and fog lights , if yes which one do you recommend to put? What would you put LED or HID ? Thanks in advance
I used HID's from DDM tuning and oem projectors for the low's and front fog's.
Low beams: H1 bulbs, 5500K, 50 watt ballasts. Fed by a relay triggered via one of the low beams. You'll want to disconnect your DRL's or they'll try to turn the low's on but you'll get no lights.
Front fog lights: 3500K , 35 watt ballasts. (with real fog, the lower the "K" number, the better you'll actually see) No harness, HID's are wired into oem wiring.
No issues with either low's or fog's after about 2.5 years.
hth
Steve
You'll also need to drill the same hole in your fog light housings...easiest to remove the housings and do it on the bench. The 7/8" hole can go anywhere you can be clearance on the housing as the replacement bulb is much shorter than the H1 bulb for the low beams.
hth
Steve
Let me know if anything doesn't make sense.
Steve
Apparently sometimes, and that's based on some reports on HID installation in the 100 series forum on mud. Searching there should help. The issue, iirc, was with 50 watt ballasts running with factory wiring. On some trucks it worked, on others not.
I wanted 6000K lights, so with 50 watt ballasts that's what I got with 5300K bulbs. Iirc, the next bump up would have been bluish, meaning less light than white.
The relay harness with fuse was only another $10.
