LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
How do I remove this 140A fuse?
Old 08-21-16 | 12:24 PM
TheDeep's Avatar
TheDeep
Default How do I remove this 140A fuse?
Folks, this fuse refuses to come out with a pair of pliers. If I try harder, I think the plastic is going to crack. Anyone know how to remove this fuse? Good place to buy a replacement?
Old 08-21-16 | 04:16 PM
hankinid's Avatar
hankinid
You pull it out, as you do the rest of the fuses. I base that on the electric wiring FSM for my '01...
More important than how to remove / replace the fuse is WHY it blew. Any ideas?
Old 08-23-16 | 03:52 AM
KiPod's Avatar
KiPod
Some of the larger fuses are bolted in from the side.
You need to separate the inner fuse box portion from the outer sleeve to access the bolts.
For some reason I remember one side being an 8mm and the other being a 10mm on one car I did.
I think they bolt them down because of the high current flow.
This is off memory but I've seen it like this on multiple vehicles.
ZoeLS430 (03-07-24)
Old 08-26-16 | 07:25 PM
hankinid's Avatar
hankinid
Maybe going to a parts store and looking at a replacement might help? The electric wiring diagram book mentions nothing special about that fuse, which the book actually terms as a "fusible link".
I just googled "toyota 140 amp fuse" and this link came up. Hope it's helpful. http://www.toyota-4runner.org/5th-ge...-solution.html
Steve
dn1ce64
08-24-17 05:50 PM
pconfar
10-03-12 07:50 AM
Maik04
SC- 1st Gen (1992-2000)
04-13-12 11:34 AM
quincy50
RX - 1st Gen (1999-2003)
12-10-10 05:00 PM
mfogaren
Maintenance
02-23-05 06:47 PM
Quick Reply: How do I remove this 140A fuse?
