ABS Active TRAC, VSC, VSC OFF BRAKE dash lights on
As mentioned in other threads it has been a rear wheel sensor or other sensor. I am wondering if anyone has had where it was the ABS Relay in the fuse box in engine compartment be the culprit for sending a code of ABS Module is not communicating? I would like to spend $100 or so on a relay than the $5k dealer wants to replace the entire ABS module and $4k at another shop.
This forum is awesome and I hope someone can help?
I'm pretty sure this is the part number, but please verify with your vehicle (I'm not sure of your year LX). You can see the part number on the outside of the ABS/VSC computer when you put your head under the dashboard. I found mine on a junk yard search on www.car-parts.com
00-02 Toyota Land Cruiser LX470 ABS TRC VSC Traction Control Module OEM 89540-60160
supergoji (03-19-18)
Thank you for your reply. It seems everybody has different fixes. I thought of cleaning ABS sensors to begin with. I also need to get the codes read so I can have a clear picture .. I hope.
