LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
P0442 Check engine light code - Evap leak?
Old 11-10-17, 06:11 AM
DONT SLEEP
DONT SLEEP's Avatar
Default P0442 Check engine light code - Evap leak?
Anyone have p0442 code before with the VSC light and TRAC light on? I used to have P0446, P0455, P0441, and P2418; but I changed the pressure sending valve on the charcoal canister. Now I have P0442 and I replaced the gas cap like most have suggested and the code is still there. The car is 2005 Lexus LX470 with 166k miles.
Old 06-04-18, 04:34 PM
Goldwinger
Goldwinger's Avatar
p0442 is a code for a small evap leak. This could be a seal on the cap. Check for rust around the filler neck or a non OEM cap can cause this. Also, the purge valve can stick and not close completely during its self-test and set a p0442 code.
Old 03-12-19, 05:46 AM
Josht
Josht's Avatar
Default Canister purge valve location
Where is the canister purge valve located on the lx470? 2005 model year
dadewi
GS - 1st Gen (1993-1997)
12
10-22-18 12:45 PM
kevin3344
05-09-17 11:22 AM
calvin2376
12-19-14 01:18 AM
Mega
09-14-10 09:08 AM
SDJZZ31
Performance & Maintenance
06-17-05 01:18 PM
Quick Reply: P0442 Check engine light code - Evap leak?
