Need some QUICK advice - single-owner 2002 w 220k miles for $8000
Hello folks, I've been looking at LX470s for a while and I thought this one was already out of my grasp but it appears a few people have passed on it. The transmission was replaced in it, so that's a big question mark.
The seller is in the process of moving and are temporarily staying with the person who is responding to the text/phone calls, it sounds like the owners are older.
I'm going to have to drive a few hours to get it, so I was hoping someone could chime in before tomorrow morning if this seems alright, and what to look out for.
Lexus service records:
REPAIR# 0085751
REPORTED BY: Lexus of Concord, LLC
SERVICE: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE
DESCRIPTION: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~95495 PERFORMED 5K SERVICE. FRONT BRAKES AT 10MM REAR BRAKES AT 10MM FRONT AND REAR TIRES AT 8/32 ANTENNA MAST IS BROKEN($225.00)
SERVICE: MISC
DESCRIPTION: MISC ~|~DROP 4 HRS MIKE E. ~|~ ~|~95495
REPAIR# 0336925
REPORTED BY: Lexus of Pleasanton
SERVICE: ALIGNMENTS/TIRES
DESCRIPTION: ALIGNMENTS/TIRES ~|~CUSTOMER REPORTS THE LEFT REAR TIRE WENT FLAT. CUSTOMER CALLED ROADSIDE ASSISTANCE, THEY CAME OUT, BUT STATED THEY COULD NOT LOWER THE SPARE TIRE. SEEMED LIKE THERE IS A PROBLEM WITH THE LOWER DEVICE. PLEASE CHECK AND ADVISE. ~|~R/R TIRE HAD NAIL , NEEDED REPAIR 3 ~|~REPAIRED TIRE AND LOWERED SPARE TIRE WITH TOOL KIT, WORKS FINE
SERVICE: LOANER CAR
DESCRIPTION: LOANER CAR ~|~SUPPLY LOANER CAR DURING VEHICLE SERVICE PLEASE RETURN LOANER VEHICLE WITHIN 24 HOURS AFTER NOTIFICATION OF YOUR VEHICLE BEING READY OR A $75.00 PER DAY FEE MAY BE ADDED TO YOUR INVOICE. PLEASE RETURN THE LOANER CAR WITH THE SAME AMOUNT OF FUEL NOTE-THERE ~|~ ~|~SUPPLIED LOANER CAR DURING SERVICE VISIT
REPAIR# 0071732
DESCRIPTION: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~84503 COMPLETE 5K SERVICE FRONT BRAKES 5MM REAR BRAKES 2MM PAD REMAINING. ALL TIRES 9/32"" TREAD REMAINING AND SET PRESSUR E TO 33PSI.. RECOMMEND REAR BRAKE SERVICE TO BE PERFORMED
SERVICE: REAR BRAKE SERVICE
DESCRIPTION: REAR BRAKE SERVICE ~|~CUSTOMER REQUEST REAR BRAKE SERVICE TO BE PERFORMED ~|~ ~|~84503 MACHINED ROTORS AND INSTALLED NEW PADS. TEST DROVE FOR NORMAL OPERATION
REPAIR# 0064049
SERVICE: LUBE OIL AND FILTER (LS400)
DESCRIPTION: LUBE OIL AND FILTER (LS400) ~|~LUBE OIL AND FILTER (LS400) ~|~ ~|~78726 PERFORMED OIL AND FILTER SERVICE
SERVICE: OPENED CUP HOLDER
DESCRIPTION: OPENED CUP HOLDER ~|~CUSTOMER STATES THE CENTER CUP HOLDER WIL STUCK ~|~ ~|~78726 CUP HOLDER STUCK CLOSED ADD STICKY STUFF IN IT ADDED DRY LUBE
REPAIR# 0060013
SERVICE: CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE
DESCRIPTION: CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~74965 75K SERVICE COMPLETED PER MENU.FRONT BRAKES 7MM REAR BRAKES 6MM PAD REMAINING.ALL TIRES 9/32"" TREAD REMAINING AND SET PRESSURE TO 34PSI.
REPAIR# 0055013
SERVICE: PERFORMED 70K SERVICE
DESCRIPTION: PERFORMED 70K SERVICE ~|~PERFORM 70K SERVICE ~|~ ~|~PERFORM 70.000 MILE SERVICE FRONT BRAKES AT 8MM REAR BRAKES AT 8MM
REPAIR# 0052025
SERVICE: TIRE REPAIR
DESCRIPTION: TIRE REPAIR ~|~GUEST STATES LEFT FRONT TIRE LOSING AIR. OK TO REPAIR TIRE IF POSSIBLE. OK REMOVE ALL WHEEL LOCKS AND SAVE. ~|~ ~|~67727 TIRE HAD NAIL REPAIRED TIRE . REMOVED LOCKING LUGS AND PUT IN CUPHOLDER TEMPORARILY UNTIL WHEEL LOCK KEY ORDERED BY CUSTOMER COMES IN.
REPAIR# 0050477
SERVICE: 65K MILE SERVICE PER MENU LX470
DESCRIPTION: 65K MILE SERVICE PER MENU LX470 ~|~65K MILE SERVICE PER MENU LX470 ~|~ ~|~PERFORMED 65K MILE SERVICE PER MENU LX470
REPAIR# 0044831
SERVICE: 5LB INSTALL DRL KIT MY03-05 LX470 (SSC)
DESCRIPTION: 5LB INSTALL DRL KIT MY03-05 LX470 (SSC) ~|~5LB LX470 DRL KIT ~|~PERFORMED 5LB CAMPAIGN PER SSC ~|~60480 CAMPAIGN 5LB IS COMPLETED
SERVICE: 60K MILE SERVICE PER MENU LX470
DESCRIPTION: 60K MILE SERVICE PER MENU LX470 ~|~60K MILE SERVICE PER MENU LX470 ~|~ ~|~60480 60K MILE SERVICEE IS COMPLETED BRAKES AT F=9MM R=9MM TIRES ARE BADLY WORN OUT ON THE RIGHT SIDE AND LEFT SIDE TIRES ARE BETTER. RECOMEND 4 TIRE
SERVICE: COMB: OPPOSITE SIDE
DESCRIPTION:
SERVICE: DRIVE SHAFT BOOT (ONE SIDE)
DESCRIPTION: DRIVE SHAFT BOOT (ONE SIDE) ~|~DURING SERVICE FOUND CV BOOTS LEAKING GREASE ON LEFT AND RIGHT SIDES ~|~CV BOOTS TORN ~|~60480 REPLACED BOTH AXLE BOOTS OP CODE 434651 T165 T212 1.4 AND .8 C
SERVICE: MISC
DESCRIPTION: MISC ~|~CUSTOMER STATES LETTERING ON REAR OF VEHICLE WAS INSTALLED WRONG AT BODYSHOP, TRY TO PUT ON CORRECTLY ~|~ ~|~60480 REMOVE EMBLEMS 4 AND 7 AND INSTALLED THE RIGHT WAY. CLEAN OLD GLUE AND ADD DOUBLE SIDE TAPE TO IT.
SERVICE: PERFORMED 4 WHEEL ALIGNMENT
DESCRIPTION: PERFORMED 4 WHEEL ALIGNMENT ~|~PERFORMED ALIGNMENT AFTER TIRE REPLACEMENT ~|~ ~|~60480 PERFORMED ALIGNMENT
SERVICE: REPLACED 4 TIRES
DESCRIPTION: REPLACED 4 TIRES ~|~DURING SERVICE FOUND TIRES WORN ON INNER EDGES ~|~ ~|~60480 REPLACED 4 TIRES
SERVICE: REPLACED FT STRUTS
DESCRIPTION: REPLACED FT STRUTS ~|~DURING SERVICE FOUND FRONT STRUTS LEAKING FLUID ~|~ ~|~60480 REPLACED FRONT STRUTS
REPAIR# 0026065
SERVICE: 143
DESCRIPTION: 143 ~|~40,000 MILE SERVICE ~|~ ~|~PERFORMED SERVICE BRAKES FRONT 4MM REAR 4MM REMAINING TIRES FRONT 7/32 REAR 7/32 REMAINING RECOMMEND TO REPLACE FRONT AND REAR BRAKES FRONT $784.00, REAR 340.00.
REPAIR# 0022300
SERVICE: NO PROBLEM FOUND, VEHICLE WORKING AS DESIGNED
DESCRIPTION: NO PROBLEM FOUND, VEHICLE WORKING AS DESIGNED ~|~CUSTOMER STATES HEARS HISSING NOISE WHEN TURNING LEFT AT END OF TURNING STEERING WHEEL INSPECT AND ADVISE ~|~ ~|~VEHICLE OPERATING AS DESIGNED NORMAL FUNCTION OF STEERING SYSTEM
SERVICE: PERFORMED 35K MILE SERVICE PER MENU
DESCRIPTION: PERFORMED 35K MILE SERVICE PER MENU ~|~35K MILE SERVICE PER MENU LX470 ~|~ ~|~PERFORMED 35K MILE SERVICE PER MENU LX470
REPAIR# 0017567
SERVICE: 30000 MILE SERVICE
DESCRIPTION: 30000 MILE SERVICE ~|~30000 MILE SERVICE ~|~ ~|~PERFORMED SERVICE BRAKES FRONT 4MM REAR 4MM REMAINING TIRES FRONT 8/32 REAR 8/32 REMAINING
SERVICE: INSPECT CD PLAYER
DESCRIPTION: INSPECT CD PLAYER ~|~CUSTOMER STATES THAT THE CD PLAYER SKIPS WHEN PLAYING CD'S
SERVICE: REPAIR RATTLES
DESCRIPTION: REPAIR RATTLES ~|~CUSTOMER STATES THAT THERE IS A NOISE IN THE REAR OF THE CAR LIKE SOMETHING IS LOOSE, LIKE THE SPARE TIRE
REPAIR# 0013199
SERVICE: 10,000 MILE SERVICE OIL & FILTER CHANGE
DESCRIPTION: 10,000 MILE SERVICE OIL & FILTER CHANGE ~|~PERFORM 22,500 SERVICE PER MENU ~|~ ~|~FRONT BRAKES AT 5MM REAR BRAKE AT 6MM
SERVICE: LUBED WINDOW TRACK
DESCRIPTION: LUBED WINDOW TRACK ~|~CUSTOMER STATES THE RIGHT REAR WINDOW MAKES A SQUEEK NOISE WHEN ROLLED DOWN ~|~X
REPAIR# 0139002
SERVICE:
DESCRIPTION: 6MM FRONT BRAKE PAD REMAINING 7 MM REAR BRAKE PAD REMAINING NEW=10MM, REPLACE AT 2 MILLIMTRS 7 /32" FRONT TIRE TREAD DEPTH 7 /32" REAR TIRE TREAD DEPTH NEW=12/32", REPLACE AT 2-3/32" SERVICE MENU COMPLETED
SERVICE: 15000 MILE SERVICE (LX450) CHECK AND TOP FLUIDS & ROAD TEST CLEAN BATTERY CABLES
DESCRIPTION:
SERVICE: AIR CLEANER FILTER ELEMENT R&R
DESCRIPTION:
SERVICE: AUTOMATIC TRANSMISSION OIL LUB
DESCRIPTION:
SERVICE: DIFFERENTIAL OIL RPL
DESCRIPTION:
SERVICE: ENGINE OIL RPL
DESCRIPTION:
SERVICE: INSPECT BALL JOINTS & DUST OTH
DESCRIPTION:
SERVICE: INSPECT BATTERY ELECTROLYTE OTH
DESCRIPTION:
SERVICE: INSPECT BODY-PAINT/CORROSION OTH
DESCRIPTION:
SERVICE: INSPECT BRAKE FLUID OTH
DESCRIPTION:
SERVICE: INSPECT BRAKE PADS & DISKS OTH
DESCRIPTION:
SERVICE: INSPECT ENGINE COOLANT LEVEL OTH
DESCRIPTION:
SERVICE: INSPECT ENGINE DRIVE BELTS OTH
DESCRIPTION:
SERVICE: INSPECT EXHAUST SYSTEM OTH
DESCRIPTION:
SERVICE: INSPECT FOR FLUID LEAKS OTH
DESCRIPTION:
SERVICE: INSPECT INT. & EXT. LIGHTS OTH
DESCRIPTION:
SERVICE: INSPECT POWER STEERING FLUID OTH
DESCRIPTION:
SERVICE: INSPECT RADIATOR & HOSES OTH
DESCRIPTION:
SERVICE: INSPECT STEERING LINKAGE OTH
DESCRIPTION:
SERVICE: INSPECT TIRE PRESSURE OTH
DESCRIPTION:
SERVICE: INSPECT WINDSHIELD WASHER OTH
DESCRIPTION:
SERVICE: INSPECT WINDSHIELD WIPERS & OTH
DESCRIPTION:
SERVICE: OIL FILTER ASSEMBLY R&R
DESCRIPTION:
SERVICE: PARKING BRAKE ADJ
DESCRIPTION:
SERVICE: ROAD TEST OTH
DESCRIPTION:
SERVICE: TIRE ROTATION ROT
DESCRIPTION:
REPAIR# 0134293
SERVICE:
DESCRIPTION: FRONT BRAKES AT 10 MM REAR BRAKES AT 9 MM REPLACE AT 2MM FRONT AND REAR TIRES MEASURE 11/32" COMPLETED SERVICE PER MENU
SERVICE: 10K MILE SERVICE (LX470)
DESCRIPTION:
SERVICE: CAR WASH OTH
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT AIR FILTER OTH
DESCRIPTION:
SERVICE: INSPECT AUTO TRANS FLUID OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT BOLTS & NUTS ON OTH
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT BRAKES OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
REPAIR# 0127570
SERVICE:
DESCRIPTION: CLIENT STATES THE SPARE HAS NAIL,PLEASE PATCH SPARE TIRE. TIRE IS NOT REPAIRABLE,NAIL IN SIDEWALL. MOUNTED AND BALANCED 1 NEW TIRE AND PLACED AS SPARE.
SERVICE: 5000 MILE SERVICE (LX470) WARRANTY SERVICE
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: TIRE ROTATION ROT COMPLETED.
DESCRIPTION:
REPAIR# 0123692
SERVICE: 1000 MILE SERVICE (LX470)
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT ENGINE OIL LEVEL OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST OTH COMPLETED.
DESCRIPTION:
REPAIR# 0039558
REPORTED BY: Jim Falk Lexus of Beverly Hills
SERVICE: INSTALL PLATE FRAMES,INSERTS, SCREWS & CAPS
DESCRIPTION:
SERVICE: PRE DELIVERY SERVICE LS400/ES300/SC300/GS300
DESCRIPTION:
Carfax report:
SERVICE HISTORY
SERVICE HISTORY FOR:9550 MILES
DATE: 07/19/2007REPAIR# 0085751
SERVICE: MISC
89705 MILES
DATE: 03/08/2007REPAIR# 0336925
SERVICE: LOANER CAR
84504 MILES
DATE: 11/18/2006REPAIR# 0071732
78726 MILES
DATE: 07/12/2006REPAIR# 0064049
74966 MILES
DATE: 05/02/2006REPAIR# 0060013
70391 MILES
DATE: 01/30/2006REPAIR# 0055013
67727 MILES
DATE: 12/02/2005REPAIR# 0052025
65591 MILES
DATE: 10/29/2005REPAIR# 0050477
60480 MILES
DATE: 07/07/2005REPAIR# 0044831
DESCRIPTION:
SERVICE: MISC
37999 MILES
DATE: 06/07/2004REPAIR# 0026065
SERVICE: 143
32887 MILES
DATE: 03/19/2004REPAIR# 0022300
27760 MILES
DATE: 12/11/2003REPAIR# 0017567
22855 MILES
DATE: 09/10/2003REPAIR# 0013199
16078 MILES
DATE: 05/29/2003REPAIR# 0139002
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
10699 MILES
DATE: 02/11/2003REPAIR# 0134293
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
5561 MILES
DATE: 09/11/2002REPAIR# 0127570
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
1786 MILES
DATE: 06/18/2002REPAIR# 0123692
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
3 MILES
DATE: 05/07/2002REPAIR# 0039558
DESCRIPTION:
DESCRIPTION:
TERMS AND CONDITIONS
INFORMATION ACCURACY
Information presented on this website is summarized and standardized from repair orders completed at the time of service and submitted by Lexus dealers. When reviewing a vehicle?s service history, please note that all information is provided by the Lexus Dealer that conducted the service, and that dealer is solely responsible for the accuracy, completeness or authenticity of any information contained in this site. Lexus provides this site and all information and materials contained herein ?as is? without warranty of any kind. Any questions or concerns regarding this information should be addressed to the applicable Lexus dealer.L/CERTIFIED OWNER INFORMATION
Dealer-reported service history records are linked to a vehicle's Vehicle Identification Number (VIN). All owner-reported service history records will be made available to the person who input the information on the site, but will not be shared with future owners of the vehicle.OWNER-REPORTED INFORMATION AND PRIVACY TERMS
Lexus makes every effort to ensure the secure collection and transmission of sensitive user information using industry-accepted data collection and encryption methodologies. The information you provide is used by Lexus and its vendors and dealers to help improve the services we render. It is occasionally provided to Lexus dealers for their marketing use. Lexus will never sell your personally identifiable information to any other company. To learn more about our privacy policies and practices with respect to this website, please click here.Carfax report:
Owner 1
Purchased: 2002
Low mileage! This owner drove less than the industry average of 15,000 miles per year.
Personal Vehicle
13,368 mi/yr
Date
Mileage
Source
Comments
04/25/2002
NICB
Vehicle manufactured
and shipped to original dealer
05/07/2002
Lexus of Beverly Hills, Inc.
Beverly Hills, CA
310-274-5200
beverlyhillslexus.co
m
4.2
29 Verified Reviews
Vehicle serviced
- Pre-delivery inspection completed
05/14/2002
15
California
Motor Vehicle Dept.
Danville, CA
Odometer reading reported
- First owner reported
- Titled or registered as personal vehicle
06/18/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Battery/charging system checked
- Undercoating/rustproofing inspected
- Tire condition and pressure checked
- Fluids checked
- Brake fluid checked
09/11/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Oil and filter changed
- Fluids checked
- Brakes checked
- Air filter checked
- Steering/suspension checked
- Vehicle washed/detailed
- Tires rotated
02/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Brakes checked
- Fluids checked
- Tires rotated
05/29/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Recommended maintenance performed
- Exhaust system checked
- Wipers/washers checked
- Exterior lights checked
- Drive belts checked
- Differential fluid flushed/changed
- Air filter replaced
- Fluids checked
- Antifreeze/coolant checked
- Cooling system checked
- Tires rotated
- Parking brake adjusted
- Brakes checked
- Windshield washer checked
09/10/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 10,000 mile service performed
- Window(s) checked
12/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 30,000 mile service performed
- Noise checked
- Radio/sound system checked
03/19/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
06/07/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
10/07/2004
43,272
Monument Auto Masters
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Maintenance inspection completed
- Front brake pads replaced
- Rear brake pads replaced
- Transmission checked
- Fluids checked
- Brakes checked
- Window(s) checked
- Steering/suspension lubricated
01/05/2005
48,261
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
03/10/2005
52,556
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
04/28/2005
56,881
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
07/08/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- CV boot(s) replaced
- Four wheel alignment performed
- Front strut(s) replaced
- Four tires replaced
10/29/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
12/02/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Tire repaired
01/30/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/02/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 75,000 mile service performed
07/12/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
11/18/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 5,000 mile service performed
- Rear brakes serviced/adjusted
05/15/2007
California
Motor Vehicle Dept.
Danville, CA
Title issued or updated
- Registration updated when owner moved
the vehicle to a new location
07/19/2007
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/14/2008
111,151
California
Inspection Station
Passed emissions inspection
06/18/2010
137,247
California
Inspection Station
Danville, CA
04/20/2011
147,138
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
12/29/2011
151,423
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
06/04/2012
154,947
California
Inspection Station
Danville, CA
09/16/2013
170,936
D & D Automotive & Tire
San Ramon, CA
925-362-8755
Vehicle serviced
04/02/2014
176,861
California
Inspection Station
Concord, CA
05/10/2016
195,423
California
Inspection Station
Passed safety inspection
- Passed emissions inspection
05/02/2018
213,611
California
Inspection Station
09/09/2019
California
Motor Vehicle Dept.
Danville, CA
- Duplicate title issued
Purchased: 2002
Personal Vehicle
13,368 mi/yr
Date
Mileage
Source
Comments
04/25/2002
NICB
05/07/2002
Beverly Hills, CA
310-274-5200
m
4.2
29 Verified Reviews
Vehicle serviced
05/14/2002
15
California
Motor Vehicle Dept.
Danville, CA
06/18/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Fluids checked
09/11/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Fluids checked
- Brakes checked
- Tires rotated
02/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Brakes checked
- Fluids checked
- Tires rotated
05/29/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Fluids checked
- Tires rotated
- Brakes checked
09/10/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Window(s) checked
12/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Noise checked
03/19/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
06/07/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
10/07/2004
43,272
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Brakes checked
- Window(s) checked
01/05/2005
48,261
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
03/10/2005
52,556
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
04/28/2005
56,881
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
07/08/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
10/29/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
12/02/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Tire repaired
01/30/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/02/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
07/12/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
11/18/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/15/2007
California
Motor Vehicle Dept.
Danville, CA
07/19/2007
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/14/2008
111,151
California
Inspection Station
06/18/2010
137,247
California
Inspection Station
Danville, CA
04/20/2011
147,138
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
12/29/2011
151,423
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
06/04/2012
154,947
California
Inspection Station
Danville, CA
09/16/2013
170,936
San Ramon, CA
925-362-8755
Vehicle serviced
04/02/2014
176,861
California
Inspection Station
Concord, CA
05/10/2016
195,423
California
Inspection Station
05/02/2018
213,611
California
Inspection Station
09/09/2019
California
Motor Vehicle Dept.
Danville, CA
I think that's a fair price and I wouldn't worry about a replaced transmission if done by a reputable shop and no accident damage associated with it. This very much matches what I found with my rig, original owner, 245,000 miles, list of every service performed. That list alone is worth 100x it's weight in gold as it seems very complete. I didn't go through the list but be sure the timing belt was done recently, and if so you're only real consideration might be that it's not a later vehicle with the extra gear. Of course try to talk them down a bit, or get some extras thrown in if they have any, and good luck to you.
