Motor replacement in LH Mirror assembly
When I purchased my ‘09, I noticed the LH mirror does not close. I have ordered a new motor for it. Does anyone have guidance or steps for replacing it? Thanks!
Haven't worked on the LX specifically the mirror assembly on the door...but have worked on other Toyota / Lexus vehicles...most likely u will need to remove the mirror assembly inner (door panel side) cover, may even have to remove the door panel..should then see a few nuts that hold the assembly in place...remove the nuts and should be straight forward afterwards.
