Bubinga wood trim replacements 2011 lx 570
you need to make a paper template of the existing piece. if you can gently pry off the damaged part and use it as a template, all the better. then get a sharp xacto knife, and some adhesive backed wood veneer, and cut out the new shape.
here is one type, but you will of course try to get a wood color that matches the rest:
