AHC rise time from Lowest ?
Hi, I tested out a LX. I go to H, it worked (quick), then down to N and Low. All worked.
Raising Low to N seemed to take a long time, N is flashing. I couldn't feel any rising. But flashing stops eventually. I tried it two times. It went from N to low quickly, but maybe height difference is not that big, it seem to take time flashing until it is N again.
Is this normal?
It's a low miles car, so should not have any problems. They said they will check it again as part of certify check list. But I will check again when I go back. I am new to these cars and it has warranty but I would like them to get this right.
Is this normal?
It lowers much faster than it raises. Rise times will vary depending on what you are doing. It can be delayed if you are sitting still with the brakes applied. This doesn't allow the wheels to adjust as it rises and can hamper the system. It can take 7 to 10 seconds fron L to N and even longer from N to H.
SC3coupe (09-15-23)
Ttkelly
GX - 1st Gen (2003-2009)
11-12-15 08:21 PM
Burst32
03-20-07 09:55 PM
