A/C Auto Mode Fault
6th Gear
A/C Auto Mode Fault
Hello everyone, I have a Lexus Lx 570, year 2013. I am having the following problem:
When I start the car, at the same time it turns on the automatic air conditioning button and after 1 minute it turns off, while it is on you can't do anything with the air conditioning. This happened to me after a battery change. Before this everything was going well. Please if anyone has an idea I appreciate it. I have noticed that the setting I left the temperature at is also lost and returns to 25 degrees Celsius. This fault occurs after turning off the car for several minutes, if it is turned off and turned on in a short time everything works normally
Make sure to read in your owners manual (or YouTube) how to do it because there’s a door that covers the filter that needs to be open by setting your ac mode to recirculate DO NOT TRY TO FORCE THE DOOR OPEN
Hope this helps
6th Gear
Hello thank you very much.
The filter is fine. It is well placed. The window works fine. It's just that error when it starts, the automatic button turns it on and until it turns off it doesn't let me turn on the a/c and about a minute later it turns off and everything works fine.
