engine misfire problem
Hello ,,
I have a strange problem which i need help to solve it .
The engine is running perfect in ideal , but when driving about 3 kilometres , it starts shaking and got obd code ( misfire in cylinders 1 , 3 , 5 , 7 .
Checked the coils and injectors all working fine !!
The check engine light will not come on while this happend even
Any idea ?
Any idea ?
Speculations:
- Faulty ignition, inclding ECU. This could be the controller, or long-term problem affecting one side and visible in an inspection of the spark plugs. It could ignition coils (make sure they are well plugged in)
- Timing chain moved/slipped
- An ECU controlling fuel injectors one side of the block not working
- Any controller affecting or a physical blocking of intake to one side
Shahabi8
06-13-19 05:21 PM
