LX 570 Dyno
LX 570 Dyno
From :20 to :40 you can see the hydraulic suspension lower at speed, then raise back up. Also at 1:10
But what is up with those numbers? I'm pretty sure it is not making 180 horsepower at 5,900rpm.
https://www.youtube.com/watch?v=iFVLYO06M2Y
is it possible the dyno is only reading the power from the rear wheels and with 4wd system sending 60% of the power to the rear wheels and the other 40 to the front. It's 383 at the crank and then you lose hp through the drivetrain so the numbers could work out. Just a thought.
