2016 LX 570 slight vibration/ grinding feel
Hi everybody, Just want to know if anyone experience what I’m experiencing. I have a 2016 LX570 , and I experience some vibration of grinding feeling as I get between 70-80mph on the free way. And it has to be between 1800-2000rpm. I feel it on the pedal and alittle on the steering wheel. I don’t hear any weird noises associated with it though.
I would Appreciate any input.
Thanks
sam
Thanks
sam
I can't see the sense between a very low profil e"P"-rated tire and a 3-ton truck. Ymmv, but I really like 18" wheels and LT E-rated tires most of the year. Winter it's Blizzak's on 18" Tundra take-off's.
Chocolate (11-12-17)
Cost savings for Toyota is the only reason unfortunately, as thin P rated tires are much cheaper, greatly compromising the hydroplaning resistance, traction, and ride of the stock vehicles in the showroom.
Result of hydroplaning on P rated OEM Dunlop 285/50/20’s I now have BFG AT/KO2’s 285/55/20’s
This vibration you describe is a common problem with the LC200 platform. There is a TSB about it but will cost you an arm and a leg unless
you are still under warranty. It’s a noisy bearing in the transfer case, I haven’t heard any stories of it causing further problems, but yes it’s annoying for such a smooth running car.
