windshield crack..2017 LX 570
Hello Everyone,
I have 2017 LX 570 that is around 8 months old. Mostly it stays in our garage, today morning I noticed a big crack in the windshield. I am bit surprised, there is no signs something hit it.. just wondering is this the issue/defect with LX windshield? Also just wondering how much will it cost to replace it? Should I replace it with the dealer only? I don't think windshield is part of factory warranty?
Thanks
Vikarm
Thanks
Vikarm
It isn't - depending on your comprehensive insurance deductible, I'd suggest that route. I'd venture to guess auto glass companies like Safelite would carry the LX570 windshield so don't assume it is a dealer-only item but your insurance company should be able to sort that out.
Not covered under warranty. Claim on your insurance. Push them for a Lexus windshield and not some crappy 3rd party windshield. The LX (and Land Cruiser) have a windshield that is 2mm thicker than industry standard for longevity and to reduce noise in the vehicle. It will be an extremely expensive piece of glass (I'm guessing $1200) and your insurance is likely to want to push you towards something cheap from SafeLite or someone they are contracted with. Remind them this is a near $100,000 vehicle that is less than 1 year old and you are concerned about value depreciation of an aftermarket windshield. Additionally a poorly fitted or fitting windshield can lead to water leakage. There are cases of LX/Land Cruisers with water leaking into the ECU that is in the dash and destroying very expensive electronics after a windshield was poorly installed. Be insistent with your insurance, that is what you pay premiums for.
Good luck
Good luck
When i’ve had my 16” LX for about four months and got small crack hit by a rock on highway, safelite tried to fix it, but still show the crack, and I mentioned to my state farm insurance that i want to replace the OEM windshield and they agreed, I contact the lexus dealer and the cost was $1560 installed so my insurance issued me a check for that amount, i kept the check and traded my 16” in for 17”, if you want the OEM it should run around $1500
Go with OEM ONLY. I work for a dealership and a few clients had their windshields replaced w/ aftermarket glass and ended up having to replace w/ OEM again because of water leak and the aftermarket curvature of the glass did not fit well w/ the wipers also. And yes, most insurance policy will pay for aftermarket glass only (IF aftermarket is available). Some clients ended up paying the difference.
Depending on your location (State).......some you can ibsiin on OEM, some not.
I would INSIST ON OEM and ASK the Lexus dealership who they use to install.
Other than OEM AND THE EXPERT INSTALLATION, YOU NOT ONLY RISK WATER LEAKAGE, BUT ALSO EXCESSIVE WIND NOISE. Back many years ago on our old 2000 LX470 we had our windshield replaced initially by a mom and pop shop with OEM in a very small rural town and it was the only Lexus LX they had done and it leaked. They said they will not try again and refunded my deductible so I moved on to Safelite about an hour and half away since no other options nearer. Safelite had not seen too many LX either. So the first ATTEMPT had lots of wind noise. So they tried and tried again. Forward 11 times!!! FINALLY the big boss came into the shop to make sure ENOUGH GLUE WAS APPLIED AND OLD GLUE SCRAPPED OFF. It took a total of 12 times!!! Unbelievable!!
Years later when I've changed insurance company they asked what happened. This stuff stays on the insurance records even though not my fault. The insurance company did not surcharge me, so that's good.
that is crazy but i can relate. i had a 06 and when i bought it it had little noise i realized it was an aftermarket glass- well changed it..and changed it again...3 times - i paid out of pocket well because nothing was wrong with it but when wind noise...in the end i glued the corners myself after peeling off the strip and had the shop apply the OEM strip again.
i realized they were reusing the older rubber or had aftermarket dressing that goes around.
when they change everything needs to be replaced around the glass.
My 2017 LX was hit by what looked like a piece of roofing shingle that flew out of the back of a truck on the interstate. It scratched the glass Badly. I have 0 dollar deductible on glass replacement and demanded a Lexus OEM replacement glass. USAA insurance uses safelite, they ordered the OEM Windshield and will replace it on the 10th of this month. I will let you know how it goes. So I would suggest doing the same with your insurance company. You may have a deductible though.
Lexus dealer in town recommended their installer...great guy who lives around 2 miles away from us. He showed up with the correct Toyota nylon-coated pop rivets, the modified rivet gun to install them, and all the new rubber moldings. Installation was done in about an hour. Zero wind noise, zero water leakage was the result. I paid him the $100 deductible charge and that was it.
Agree with OEM recommendation
I agree with all about OEM windshield. Only needed one new windshield on my last LX over 8 plus years, which is really great in Colorado. Rocks and hail wreak havoc on windshields here. Took a few years for a pretty big "star" chip to start a small crack. My experience is that OEM glass is better. Insurance let me order it through the dealer and the dealer had the glass company they use install it in a dealer bay -- the total price was no more than if S lite had ordered it through Lexus and installed it. Plus, that way vehicle got one of nice hand washes at the dealer.
Hello Everyone,
Thanks
Vikarm
Thanks
Vikarm
hth
