Wont' shift out of gear P after battery change
Lexus 2008 LX570
I replaced the battery and found out i can't shift out of gear P. Checked the fuse, reinstalled battery, and manually release the gear, but all failed. Anyone know if the gearbox would be locked after battery change?
Much appreciate for any inputs. Thanks in advance.
There is a "hole" covered by a small black plastic cover next to shift lever. Pop it out (don't loose it) and put in a small flat head screwdriver and press down while you step on the brakes and then you can move the shifter lever.
Lexus 2008 LX570
I replaced the battery and found out i cae shiftn't shift out of gear P. Checked the fuse, reinstalled battery, and manually release the gear, but all failed. Anyone know if the gearbox would be locked after battery change?
ZuerstBMW
04-09-17 11:14 AM
DzaztrBUSE
04-05-13 06:45 AM
