LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
As gas prices rise, will you deviate from Premium?
Old 07-13-18, 04:32 PM
  #91
Htony
Htony's Avatar
Originally Posted by hankinid
[OT]...Liberals' main arguments revolve around who's gonna' get the money from taxes. Having lived in Texas for 15 years and the same in Idaho, it's refreshing to have a government that expects you to solve your own problems. [/OT]
If that is the case, we don't need a government, do we?
Old 07-13-18, 05:16 PM
  #92
hankinid
hankinid's Avatar
Other than providing for a nation's defense and interstate or inter-region highways?
Old 07-13-18, 06:36 PM
  #93
hankinid
hankinid's Avatar
Ignorance does not have color. We're in 21st century in transition to alternative energy vehicles. I often wonder some people skipped chemistry, physics classes in school. One step further thermo dynamics, fluid dynamics, electro-magnetism, etc,etc. Now car looks more electronic than mechanical..
One of the cardinal reasons for choosing the Land Cruiser and its offspring(s) are inherent reliability during Toyota's service life of 250K miles and 15 years; that, and relatively ease of repair on or off-road if necessary. I'd predict both factors decreasing a bit as the trucks become more electronic and less mechanical.
Old 07-13-18, 08:25 PM
  #94
hankinid
hankinid's Avatar
As for the parts content. Take a look at the window sticker of a new Land Cruiser in the United States. (Not sure where you are located?). I was astonished to noticed that it was 5% US sourced. I do have a website link I can send you later but I am on my way to a concert right now.
We we have a LX450. Used to have a 470. Our manual says regular for the LX. My 4Runner states regular required but for optimal performance use premium. When we had a 470, it was premium fuel only.
What LX do you drive? Or do you have a Land Cruiser?
I would think the 5% U.S. content relates to port added options...like floor mats, hood protector ,glass breakage sensor, etc. I know the floor mats are made in the USA.
Old 07-14-18, 06:30 AM
  #95
Honestly, it could be anything really. I would figure it could be those interior door handle pulls.
Here is the parts content from the NHTSA, as you will see, 5% of the LC200 parts is US/Can sourced.
https://www.nhtsa.gov/sites/nhtsa.do...rcent_year.pdf
File Type: pdf
Old 07-14-18, 06:42 AM
  #96
Most LX owner on this forum are probably not making a living using LX as a work truck hauling or carrying heavy load. When engine is working hard concern for ping is real with regular gas.(ECU can't retard timing indefinitely)
Any how if one wishes to keep the car and want it run in tip top shape I'd think premium gas is better choice than regular gas to be on the safe side. Cleaner engine and no worrying about ping.( Some drivers may not even know when the engine is pinging)
You are correct. If there was engine pinging, the owner of the LX570 would/may have no idea. Knock sensors wear out as well I thing. It is a very interesting argument of how the LC200 does not require premium but the LX does. Another interesting thing would be why does the LC200 5.7/LX570 in world markets outside of the US make 362HP on premium fuel with e slightly different engine tune?
Old 07-14-18, 08:42 AM
  #97
hankinid
hankinid's Avatar
The owner of the LX would not hear or feel the pinging, as the knock sensor retards timing just enough to stop the pinging. A defective or worn out knock sensor will result in a CEL...e.g., code P03XX will show an issue with a knock sensor, the "XX" will populate with 2 numbers which identify which sensor is defective. Checking the sensor is simple...there should be no continuity between the sensor terminal and chassis ground...a test light or simple ohm meter is all that's needed.
Lower hp numbers in non-North American trucks is simply because of octane differences in other markets as an earlier post here indicates.
Old 07-14-18, 09:24 AM
  #98
How could octane be lower in different parts of the world be the factor ? The 5.7 is rated for 91 in all applications outside of the US. 87 is not a typical gas option outside the Americas. Also, the torque peak is tuned 400 rpm lower in non US 5.7 models. 3200 vs 3600 for USA
Old 07-14-18, 09:47 AM
  #99
Htony
Htony's Avatar
Different cam shaft/sprocket design? Torque peak coming early mean timing advance is more aggressive? In old days I used to play with timing advance springs in the distributor. Lighter springs advanced
timing at faster rate to gain max torque early. Now this things are all under electronics control.
Old 07-14-18, 10:16 AM
  #100
hankinid
hankinid's Avatar
Check posts #52-54 in this thread.
And I'll add...what kind of fuel MBZ recommends, suggests, or requires may be interesting, but I'd opine it's completely irrelevant to the discussion here. MBZ's are not (hardly) designed for a 15 year 250K life cycle...not in the slightest.
Kbach
GX - 1st Gen (2003-2009)
388
11-30-20 03:05 AM
jzdulexus
134
05-31-16 07:45 PM
tripplej
15
12-17-11 12:19 AM
darrellk
16
02-19-06 06:28 PM
Quick Reply: As gas prices rise, will you deviate from Premium?
