After going through as many of the off-road tire threads as I could, I settled on the 275/60R20 BFG K02s for my 2011 LX570. These are replacing Michelin Latitudes in the stock 285/50R20 size at about 4/32s tread depth remaining. Here is what I can report (just my personal experience).
No rubbing that I could hear or feel on the highway or neighborhood roads during normal driving in any height mode.
Rubbing with the steering wheel turned to the stops as follows:
High height; Wheel turned all the way left:
FL: slight rub on mud flap
FR: clears front wheel well by about a 2cm
High height; Wheel turned all the way right:
FL: clears front wheel well by about 2cm
FR: slight rub on mud flap
Normal height; Wheel turned all the way left:
FL: clears mud flap by about a millimeter
FR: clears front wheel well by about 2cm
Normal height; Wheel turned all the way right:
FL: clears front wheel well by about 1cm
FR: rubs mud flap
Low height; Wheel turned all the way left:
FL: clears mud flap by about a 1mm
FR: clears front wheel well by about an 1.5cm
Low height; Wheel turned all the way right:
FR: rubs mud flap
Picked them up from discount tire, so currently debating returning them for the 275/55R20s (the size they recommended), or deleting the mud flap.
I could not notice a discernible difference in tire noise or ride quality.
Hope this helps. I will upload pics and hope they stay in the order above.
High Mode; Wheel Left; Front Left High Mode; Wheel Left; Front Right High Mode; Wheel Right; Front Left High Mode; Wheel Right; Front Right Normal Mode; Wheel Left; Front Left Normal Mode; Wheel Left; Front Right Normal Mode; Wheel Right; Front Left Normal Mode; Wheel Right; Front Right Low Mode: Wheel Left; Front Left Low Mode; Wheel Left; Front Right Low Mode; Wheel Right; Front Left Low Mode; Wheel Right; Front Right
Thank you for sharing and for choosing Discount Tire, 11lx570!
Another option is to heat up the plastic where the tire rubs with a heat gun and push it inwards. I've also seen guys drill two small holes in the inner fenders, and either wire tie, or zip tie them back.
I went with the heat gun option on the inner portion of the front mud flaps. Happy to report that I haven't had any rubbing at any height, wheel position or in reverse. I did some very easy off-roading, and I didn't hear or see any indication of rubbing while navigating through ruts or uneven ground.
