2018 LX570 Differential Fluid
Hi All,
I am considering changing F and R differential fluid. I wonder if our LX570 come with slip differential? I am considering using mobil delvac synthetic gear oil 75w-90. I believe this one does not come with slip differential additive. Therefore I just want to make sure if our truck come with slip differential. Has anybody use this fluid before? Should I use Mobil 1 75w90 LS? Any input will be great!!
Aldous
Aldous
For all the fluids, I've always had Lexus dealership take care of it, so I may not be able to give the best advice on this. However, I looked up in the past threads and found something relevant to your question. It may help with your question:.
Here is the thread:
https://www.clublexus.com/forums/gx-...id-change.html
Hope this helps!
Here is the thread:
Hope this helps!
aldouschiu (03-12-19)
Hi All,
Aldous
Aldous
Here is the thread:
Hope this helps!
Here is the thread:
Hope this helps!
Toyota recommends their 75W oil for the 200 Series transfer case. Given Toyota's pricing for the fluid, I elected to use Ravenol MTF-3 since it's been tested to and labeled as meeting Toyota's specifications. I bought it on Ravenol's website as it's not something you'll see at your local parts store.
Telephone calls to 6-7 regional Lexus dealers indicate they normally use Valvoline or Mobil 1 75W-90...great for the differentials but NOT for the transfer case. Some mention on Mud that 75-W90 may cause issues with the TC unlocking when it should be locked...something I've not experienced. Most attribute the issue to not using Low range enough if at all.
A how-to video on Mud is here...Series 200 differential and transfer case fluid changes. I use a compressed air powered filler that works perfectly...Easy to use fluid filling system
hth
The following 2 users liked this post by hankinid:
aldouschiu (03-12-19),
mmalik (03-11-19)
All the LX570/LC200 have open front and rear differentials. Wheel slip is electronically controlled through the ABS braking system. The center differential/transfercase is different though and contains a mechanical differential lock that is electronically accutuated (switch on dash by right knee). It requires particular fluid as mentioned above, Toyota or Revenal (can be found on Amazon).
Here is the thread:
Hope this helps!
Here is the thread:
Hope this helps!
The following 2 users liked this post by glemmen1:
Rki2019 (02-14-20)
I am changing differentials and transfer case fluid for my 2017 Tundra at 30k. I was debating if I should change for my 2018 LX570 or should I wait till 30k. It has little over 8k now. A friend told me he did his at 7k after break in. I am still debating. May be it's premature. I should wait at least at 30k!
See above. When I did outside sales in the southwest, I could easily drive 30K a year in my company-provided (thank you, God) 4wd Chevy or GMC Suburban. If op drove for business like I did, I could see 30K if his '18 was sold in early 2017...my current LC is a '13 but door sticker shows it was made in 2/17.
I am not towing or anything as I have 2017 Toyota Tundra do towing etc. I will see how bad my Tundra fluid looks when I change at 30k. Only cost about $80 to change F/R differential and transfer case as I change them myself. Just drain and fill. They are fairly easy. I just like the idea change after break in!
As I posted above, half a dozen Toyota, Lexus, and Toyota/Lexus dealers told me that they used either Mobil 1 or Valvoline and not Toyota fluids.
Use whatever you like.
