60k Service
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
That's the same as my '13 Land Cruiser.
That is not correct info. The 2017 owners manual says 75W-90 in the differentials, and 75W in the transfer case. Your service advisor may have his head where the sun doesn't shine. 75W-90 is not used in differentials without a limited slip additive...no matter as the series 200 trucks don't have limited slip diffs. Toyota recommends different fluids between diffs and transfer case.
Toyota Genuine Differential Gear Oil LT 75W-85 GL-5 or equivalent
Toyota Genuine Transfer Gear oil LF or equivalent SAE 75W
There's no viscosity specified for the transfer case so I had to put my faith in the service advisor. It does have a Torsen limited slip differential.
The 2017 manual from Lexus states:
