Stripped drain plug
Hey guys,
I have stripped/rounded front diff drain plug of lx570 2008, spare is days away.
Im thinking about welding a hex 10mm driver and try to take it off.. what do you suggest?
Thanks and regards
And all have a Merry Christmas and a wonderful covid free new year.
Thanks and regards
Tack welding something on is usually the best option, sometimes it takes several weld attempts. I can usually get them off by hammering in a torx bit but it does tend to sacrifice the bit.
You could but then you risk not being able to remove it again easily.
With a fresh washer you should be able to tighten it enough to seal...and use a 2nd new washer on the replacement plug. I'd buy 2 plugs as the same pn also fits the transmission.
It's going to heat everything. I had an issue with an o2 sensor. Let the engine run a little bit until the pipe was warm/hot, and then unscrew. In any case, I would suggest to sacrifice a bit. If not, get some locking vice grip in combination with heating. But I would wait until I get the new plug before try removing the old one. Patience will get you through.
dcdyd
04-11-13 08:58 PM
