LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
No Sound, no volume control?
Old 10-17-21, 02:59 PM
Reggie1
Reggie1's Avatar
I have a 2013, and I just installed my third ML amplifier last week. There are 2 fuses that may be blown. Are both OK?
I hope you disconnected the battery before you plugged the 3 connectors back into the amp. The instructions from the rebuilder for amp #3 were pretty adamant about that step. He even included a sticker on the unit itself with the same caution note repeated - “ Disconnect vehicle battery before attaching connectors!”
Old 10-17-21, 03:43 PM
SloanSav
SloanSav's Avatar
[QUOTE=Reggie1;1114682] Oops. Mine had no such sticker after receiving mine back. Seems to not have had an effect. I opened the hidden menu and the menu shows my AMP as OK. Might have gotten lucky.
I recheck the two fuses - Amp 1 a 30 amp fuse and Amp 2 a 15 amp fuse. Both were good. Has to be one of the relays, right? Not sure which one and I lost my multimeter. Which I probably wouldn’t know what to rest for anyway. Probably need to buy one, but know I would come back from Home Depot with things I don’t need.
Old 10-29-21, 05:25 AM
Reggie1
Reggie1's Avatar
Originally Posted by halovoa
Had the same issue one year ago, and it happened occasionally but not always. So I had to go to dealership couple times and finally luckily enough, the master tech was able to see the issue and inspect it. It was the amp issue, mine was over heatting so it would not start sometimes. Replace the whole amp under warranty and now after one year, the car starts to have the same issue again. I highly doubt this might be a design issue for audio system in lexus LX. My car is 2016 lx570 and I might considering getting a new generation LX when it comes out due to this issue.
Interesting. Finally a Lexus employee admits that overheating is an issue killing these ML amps. I am on amp number three in my 2013 LX. It makes no sense that the amp has 2 cooling fans, but the amp and it’s fans are placed into a well under the driver’s seat where airflow is minimal. And after the amp is in place, the carpet is installed over the top of it, further cutting off any air for cooling. Last replacement I cut out a big window opening in the carpet so the amp can breathe. I’ve not noticed any change in interior noise.
Old 10-29-21, 12:52 PM
jsch222
jsch222's Avatar
I'm curious if you noticed the volume being lower before it died? I dont drive my LX every day, but i swear that if i have my volume on 25 it is drastically different from time to time. I am wondering if it is the amp being heat soaked and not providing proper output.
Old 02-02-23, 04:54 PM
29er
29er's Avatar
Was this issue ever solved? I have a very similar problem, and I'm at a loss for what it could be. Any help would be greatly appreciated.
Old 02-02-23, 05:11 PM
SloanSav
SloanSav's Avatar
No, sadly, I did not. Ended up being the head unit. There’s a company that repairs them if you believe it’s the head unit - service@hitechserv.com. To be honest, I never sent mine off due driving a vehicle without a head unit.
Ended up trading in. Couldn’t beat the value; first and only time I’ll profit off a trade-in. Especially since the dealer wanted $1,800 for a new head unit.
Old 02-04-23, 06:12 AM
05ls430518
05ls430518's Avatar
If your having issue send them to Joe at oem audio, he can fix broken headunits, amps, etc there is not anything electrical he cannot fix.
https://www.google.com/search?q=oem+...obile&ie=UTF-8
Old 02-07-23, 07:49 AM
Reggie1
Reggie1's Avatar
There is a component of the audio system located under the front passenger seat which will also cause similar loss of sound. It may have been at fault if the amplifier tested as good. Off hand I cannot recall the name of the component. Can someone help?
MK4Sup_isF
12-26-19 02:40 PM
dlynch
RX - 3rd Gen (2010-2015)
01-28-19 01:12 PM
johnjg3535
07-31-14 12:17 PM
stewbertso
03-29-14 01:03 PM
cmotomn
07-26-11 12:56 PM
Quick Reply: No Sound, no volume control?
