AHC system replacement cost
Hello,
If and/or when you are looking to replace the entire AHC system with a regular suspension setup I would be willing to take the old components off of your hands for a price. Just let me know what works best for you!
Thanks,
Brandon
Thanks,
Brandon
It's very rare that AHC repairs are that involved. Most times it is the globes/accumulators that need to be replaced and very rarely I have seen a shock or other component needing replacing. But 9 times out of then when its time to service the AhC it is new globes and fluid flush. You can DIY it at home without a lift. It's very simple and a good learning experience.
I am wondering if I could use any other type of line or if I need to try and deal with the dealer more... Is this the line that usually fails for rust that jat0223 mentioned? Any help advice would be greatly appreciated!
baktasht (06-04-23)
I had my AHC system spring a leak the other day. Made a mess in my driveway... I called the dealer for a replacement line and I was told that they would need to see the car to determine the part. I have a friend with a lift so we were able to see it. The line starts near the accumulator and makes a 90 degree turn near the drivers rear side and then it looks like it has a compression fitting. I did not take a picture of the leak location as I thought the dealer would be able to sell me a part based on the picture I have. This picture was taken under the car looking aft the passenger rear wheel well is on my left. The line looks to be some sort of 1/4 inch line and the leak is at or after the 90 degree turn on the driver's rear (on my right in the picture).
baktasht (06-04-23)
I am guessing The part is 48998-60010. Order it from partsouq or any Toyota dealer or Lexus. Shop around
baktasht (06-04-23)
