Problems with Headlight "Swoosh"
Hello,
I have a 2016 LX with 155k Miles that has a problem with the headlight "Swoosh" lights / running lights. It began about a year ago when they started turning yellow instead of the crisp white. Now one has gone out completely and the other appears to be on its last leg.
The dealer took a look and said its all one piece / part of the headlight and I would need to replace both headlights to fix at a whopping $10k total once you factor in each headlight, time to install, calibration, etc.!
Has anyone else run into this yet? No way I am dumping $10k or one quarter of the vehicles total worth into just running lights! LOL
I am hoping someone has a workaround or a third party option...
Thanks!
Thanks!
10k to replace both headlights? If you do want them replaced, either you buy the parts and install by yourself (not sure if it needs calibration - if it does bring it to an indy / even dealer w/ techstream)....otherwise bring it to an indy (or even bodyshop to have them replaced.
