I see that the fuel tank in the LC200 comes in two sizes. One with and one without an aux tank.
80L = 21.1 US Gal
110L = 29 US Gal
Anyone know which one we are going to get? I am assuming that we will only get the smaller option.
Thanks!
As usual in the North American market, it gets a single tank. As with the 200 series, you can probably add a second tank using Toyota parts. You're looking at relatively expensive parts for another 8 gallons, and the parts normally come from Australia or the Middle East...i.e., a US dealer can't order the pieces.
Start shopping for the bolt-in parts. You should be able to get them from a parts place in Australia or the Middle East. A complete guess...You'll spend $1K minimum. You'll also need wiring for the 2nd tank fuel gauge...not sure if it's dedicated or switched with the dash gauge.
I am trying to find a solution to the fuel range on my LX600. Love the vehicle, pleased with everything about it...except for the dang fuel capacity.
I found the Brown Davis 87 liter sub replacement tank out of Australia. I have emailed Brown Davis to see if it might work. Its built for the 300 series landcruiser to replace the sub/aux tank (which we didnt get either in the US).
Anyone see any reason I cant make this work?
or any other options? I just cant stand 290 miles range which is what I am averaging right now. And I havent even towed with it yet. Thanks!
There is only one person I know who was able to add a OEM subtank to the 200 series. Assuming the 300 is similar it’s almost impossible. Your only option would be ro find someone who makes a larger main tank (never happened with gas 200 series) or LRA to add an aftermarket subtank (not sure if they have one for the 300 yet).
Take a look at the 200 and 300 series LX and Land Cruiser on ih8mud.com.
