Passenger seat heater not working
Driver seat heater working
Light on switch for passenger side not lighting
Check 15A fuse and it's ok
What do y'all think it could be ?
Bulb in the switch blown? Does the seat still get hot? Check the electrical connections under the seat (motor it forward all the way to ease access). Pop the switch panel up and check the plug is connected properly (From memory, there is one plug that does both seats). Double check fuse with a continuity tester. Some fuses although they do not appear blown, actually have hairline cracks in them.
Good luck
Good luck
VVT-i,
When you say new seat cover, do you mean whole new leather seat cover?
I spoke to an independent mech. who said the original cover can be reused.
I have a '97 ES 300 and the driver seat heater element is burned out.
Thanks
Thanks
