belt noise...
belt noise...
hello everyone,
i have a 2000 gs4 i really dont drive the car, its been sitting for about 3 weeks or so cause the weather has been bad...but i just recently started my car up and drove it a little....now the belt make a very loud squelling noise... a friend of mine says all i need is some belt dressing... now im turning to my CL members for advice... the car has only 45,000 miles to my knowledge, i dont think it needs a belt... or does it???
my 02 ES started to make some belt noise. Before you use a belt dressing (fixes the symptom NOT the cause) have the tension in the belts adjusted. They may just be loose. It is a simple adjustment made by any mechanic or DIYer. On the ES the ALT belt is easy to adjust, the PS belt had to go to the service guy to adjust. Now, not a sound is heard.
If the belts are dried and starting to crack or frey, then be safe and have them replaced.
steviej
steviej
Re: belt noise...
Originally posted by lsportlex
hello everyone,
hello everyone,
The idler pulley is located between the intake tube and radiator hose.
Chu...
Originally posted by steviej
he is not in Guam, he is in Rhode Island, but you have an excellent suggestion.
Chu...
much thanks for all the info fellas......hey steve where in mass are you located??
Watch the Regional meetings forum. There is a spring meet in the works for MA.
Where abouts are you?
Back to the belts, when you start the car up on a cold morning, and then gently turn the steering wheel, do the belts squeal? Or does it only squeal when you push on the gas, like when you are warming the car?
They are only rubber and will stretch over time and the tension will need to be adjusted. My old car has spring loaded tensioners, so adjustment was constant and I never heard a squeal.
good luck.
steviej
There is no adjustment on the belt on a GS400/430. Try belt dressing or drive it for a while and see if it goes away. If it doesnt and it is the belt it will cost about $97 for the belt plus maybe 1.0 hr for install.
Eric
Eric
im in the providence area... employee at hi-tech auto salon, heard of us?? yeah if there is a club lexus meet i would be excited to attend it and see who is who.. im kinda new to this site and not sure how things are set up... but everything about this site has been cool...
about the belt i only makes noise when i rev the engine..so i guess i have to get the car serviced and get a new belt cause i cant adjust it...WELL THANKS FOR ALL THE INFO EVERYONE...
Eric
Eric
sj
GS3/4 does not have any tension bolts. The belt is self-tensioned through a tension pulley that is spring loaded inside. 1 belt drives everything (AC/ALT/Powersteering/...) I don't use belt dressing. The only quiet the belt for a few days and you have to use it again, and it get worst everyday.
maybe from the moisture...
it could just be from the moisture which causes your belts to begin to squeak. Try to first put a type of lubircant, since i own a mechanics shop i just use white lithium grease. If this problem presists in the future, then you need to get it checked out, it maybe be a tensioner or pulley.
Re: Re: belt noise...
Originally posted by ChuH
It may not be the belt. It may be the idler pulley. I am having my replace under warranty next week by the dealer for the second time. Guam is quite humid and tropical air which cause the bearing to rust. To find out if it is the idler pulley try squirting some WD-40 or lithium grease between bearing and face plate. If the sound disappear it is the idler pulley.
Chu...
Chu...
acarapella
20
01-12-18 06:06 PM
jcho11
11-30-17 07:43 AM
