Torque specs needed on Transmission pan bolts. GS400
Old 02-05-04, 07:17 AM
LudEcrous
LudEcrous's Avatar
Question Torque specs needed on Transmission pan bolts. GS400
Can anybody with a GS repair manual provide me with the torque specs for the numerous 10mm bolts that hold up the transmission oil pan on a GS400?
Thanks.
Old 02-06-04, 08:11 PM
99lsguy
99lsguy's Avatar
Since you said GS400, it must be 98-00 year.
That being the case, it is the same engine in the LS400, 98-00 years.
My 99 LS manual says 19 bolts torqued @ 65 in. lbs
Don't forget the gasket specs:
THREE BOND 1281 or equivilent, bead should be uniform 2-3 mm wide around pan.
Old 02-07-04, 10:48 PM
LudEcrous
LudEcrous's Avatar
hey thanks a lot!...it is for a 98 gs400.
would you also happen to know the torque spec for the trans drain bolt?
Old 02-08-04, 08:21 PM
99lsguy
99lsguy's Avatar
absolutely,
15 ft. lbs for transmission drain bolt
Not very much, but its "by the book" and never leaks....
Scott1258
RX - 1st Gen (1999-2003)
12-04-17 04:34 PM
91Soarer
Performance
07-14-13 06:02 PM
LudEcrous
Performance
08-09-12 09:04 AM
ICEBERGS
08-19-09 03:02 PM
Quick Reply: Torque specs needed on Transmission pan bolts. GS400
