oilpan reseal
oilpan reseal
anyone know the recommended torque needed and the tightening sequence for the lower oil pan on the 1991 LS? I need to know before i reseal it and replcaea the gasket
I don't know about that particular model, though either the Haynes manual or or the Chilton's manual (or both) would have it in there. Both come in very handy when performing maintenance on your own car. I know most vehicles are only 8 to 10 lbs. or so though, so not terribly tight... just enough to keep the oil in and the gasket squished enough to not let it out.
When doing it though, it always helps to double, triple, and quadruple check every bolt, as the gaskets usually crush a little and when going back around, you'll find that when you tighten one side, the other then has extra play in it and you'll have to tighten those.. Anyhoo, good luck with it!
Mine shows 12 bolts and two nuts - Use several ( as in at least three) passes to uniformly tighten.
Follow the litte groove in the pan between the bolts and then just swing the bead to the inside of bolts at those locations
3-5 mm wide bead so that's about 1/8 to 1/5 ".
Talked to the dealer
The repair manual and parts fische shows no gasket for the oil pan. The manual shows applying a small bead .012" - .016" wide of sealant (toyota part #08826-00080) on the oil pan mating surface. Within 5 minutes of applying the sealant, the oil pan must be put in place. The manual shows no tightening sequence but the final torque should be 69 in-lb.
Originally posted by persian451
i dont know
i dont know
